Author Topic: 1976 CB750 Overcharges  (Read 1286 times)
Offline rtbmrgl
  • Got Points! Roseville, Ca
« on: December 12, 2014, 10:20:50 AM »
Hello,
I checked charging voltage on my K6 and the voltage at the battery at 5K rpm is 15.1v. 14.5v should be max, can the regulators be adjusted, or would an electronic reg/rectifier be a better choice. Around town driving wouldnt be a problem, 3-4k rpms are about 14v, but extended hwy it would overcharge battery boil out the water.
Suggestions.
thanks, Mark
Roseville, Ca
Got Points!
1973 CB500 back yard find 1243 orig mi,  http://forums.sohc4.net/index.php?topic=124285.0
1976 CB750 Restoring,        http://forums.sohc4.net/index.php?topic=132997
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=dvr35uf6gur6cc2itmbag4urd5&/topic,60973.0.html
Re: 1976 CB750 Overcharges
« Reply #1 on: December 12, 2014, 01:27:36 PM »
id you use running light.can it not take the overload.?..on my 550..i have a bit heigh volt..but use to turn the light on..then it just fine
..if i have to idel for longer time i can run vitaut the light.(in city) etc   .there are not a perfekt volt adjusting vith the standart systemyou can adjust the load rele...but thek the manual to do it korrekt
i hate all this v-w.... vords
« Reply #2 on: December 12, 2014, 01:57:17 PM »
check the voltage difference between the regulator black wire and the battery positive,if the black is lower by much the reg will think the battery is down and up the voltage overcharging it,they should be pretty much the same with the black slightly less through connections,make sure the connections are clean right through the loom.
Offline rtbmrgl
« Reply #3 on: December 12, 2014, 03:14:08 PM »
Thanks for info, Ill do more investigating this weekend, also I havent check charging voltage with lights on.
Ill get back
thanks, Mark
Roseville, Ca
Got Points!
