Author Topic: CB450 Top end Rebuild  (Read 5650 times)
Offline holyspokes
« on: December 14, 2014, 11:35:12 PM »
I know this is SOHC/4 but, I'm sure you guys have a lot of good info and experience with twins as well.
I have a 74 CB450 that blew a piston. I'm in the process of rebuilding the top end and I found some damage to the head. There are small chips out of the head around the valves.
Can I continue with the head in this condition or what would my next move  be?
Right cylinder with blown piston:
Left cylinder head
Offline holyspokes
Re: CB450 Top end Rebuild
« Reply #1 on: December 15, 2014, 08:24:55 AM »
Thanks man will do!
Online grcamna2
« Reply #2 on: December 15, 2014, 08:42:06 AM »
Do you access to a valve spring compressor ? if so I would remove the valves & springs(tag each bag for left and right & keep the springs to each valve) and then clean up the valve seat area w/ a small wire brush,scotch brite,etc. so we can all see the condition of the valve seats.I see the chipping around the head gasket area(which doesn't seem very critical to me)and if we could all see the combustion chambers w/o carbon it would make it easy to tell if there's any problem.
Offline holyspokes
« Reply #3 on: December 15, 2014, 09:26:06 AM »
No valve springs on the 450 has a torsion bar setup. The chipping is around the valve ring as well as the combustion chamber. Looks like I'll be looking into getting it machined..
    • http://forums.sohc4.net/index.php?PHPSESSID=5tji5h8mmb1c6ln631k3063u27&/topic,60973.0.html
« Reply #4 on: December 15, 2014, 10:20:36 AM »
put a plug inn and fill fuel in the komp champer..and see if it leakes down...if not..it can be ok....small marks can be polished down..in the aleminium parts
is there not a cast iron dome in 450 heads...or is it a 500 t head..have it run lean..and melted hole in the pistom dome??
Online grcamna2
« Reply #5 on: December 15, 2014, 10:53:13 AM »
Sorry,forgot.OK no valve springs makes it easier to remove the valves and inspect the valve seats
Offline holyspokes
« Reply #6 on: December 16, 2014, 06:25:38 PM »
Thanks, I'll try the leak down test once I get it back together. I've checked around with some auto machine shops to get the heads re machined and prices are unreal! I have a NOS set of pistons coming shortly. I'm going to button everything up and see what happens while I search for a donor engine. Thanks for the replies everyone!
Any advice on reassembly? mainly concerning lining the cams up, cam chain, etc. I have a manual, but first hand experience is always appreciated.
Thanks!
Online grcamna2
« Reply #7 on: December 16, 2014, 08:18:42 PM »
holyspokes, Make sure to take it to a machine shop who likes to do Japanese motorcycles & is already set up to do them;I know of a good one who's in the W. MA. area and his prices are Right  ;)
Online grcamna2
« Reply #8 on: December 17, 2014, 05:45:33 AM »
Reach out to CB750CafeRacer (he's in Long Beach). He will have a qualified and reasonable referral for you.
I'd machine it before wasting time and energy buttoning it up, but that's me.
+1
« Reply #9 on: December 17, 2014, 07:26:02 AM »
the leak down test..are done upside dovn..on you tabel..just teight the tensins speing..and fill gas in the head
klik on photo to get it bigger
Offline Bill/BentON Racing
    • BentON Racing
« Reply #10 on: December 18, 2014, 05:29:02 AM »
May have some parts if needed, Bill
Here's a couple pics of the last one I dd, dem heads and valve train mucho different!
BentON Racing Website
BentON Racing Facebook
Offline holyspokes
« Reply #11 on: December 18, 2014, 02:09:48 PM »
Wow that engine looks incredible! Wish mine looked like that.
So after looking at the spark plug, I believe the piston failed due to overheating on that side. From what I read this could have been from incorrect spark plug heat range and improper ignition timing.
The top end was last done by a shotty local mechanic (my fault for not recognizing the red flags that he wasn't skilled enough for the job). Is it possible that this happened because he set the advance wrong? Got the bike back with multiple leaks, and excuse after excuse. Even had to take it back to redo the valves as they were clattering like crazy. Would have done it myself but felt I had to get the work I paid for :)
I'd love to get the heads machined, cylinders bored, and larger piston set, however funds prevent me from doing all this right now. I figured with another set of new CB450 pistons I already have, I could button it up the way it is and run it. If the piston damage wasn't due to the scoring at the top of the head, any reason to believe this wouldn't work for a while anyways?
I plan to tear down and re do in the future, but while I'm waiting to rebuild or find a donor engine I might as well run it anyways right? A rebuild is due for the future regardless anyways.
Online grcamna2
« Reply #12 on: December 18, 2014, 03:03:46 PM »
A leak test of the valves while the engine is apart can sure save you lots of time and aggravation later;see what strynboen said in his earlier post.I hope you have the new pistons 'Fit' correctly to the cylinders and glaze break/hone for new rings.
Offline holyspokes
« Reply #13 on: December 18, 2014, 04:02:21 PM »
thanks everyone. Ive not done a leak down test before. How would I do this with the head off the bike? Thanks!
Offline holyspokes
« Reply #14 on: December 18, 2014, 04:44:46 PM »
so with the head upside down, rotate the cams until the valves seat, fill with gas, and see if any leaks through and out the bottom?
Thanks all
Offline Drew_ATL
  • What’s a Torque Wrench?
« Reply #15 on: October 04, 2018, 08:40:39 PM »
Can't wait for Bill to work on my '71 CL450 Scrambler!
I blame Bill, he made me love these bikes! :)
...respectfully watching and learning.
