Author Topic: sprocket upgrade  (Read 1030 times)
Offline mcgreens
sprocket upgrade
« on: December 21, 2014, 12:56:51 PM »
    I have had to replace the rear wheel on my 1976 550F, and thought it would be a good time for a rear
sprocket upgrade.  I have looked all over for a 41 tooth sprocket for this bike and have come up empty. My question is,can I
use say the 41 tooth sprocket from a 750 of a similar year (75/76/77)? Or point me in the right direction on locating
one that will work?
Re: sprocket upgrade
« Reply #2 on: December 21, 2014, 02:58:31 PM »
that will gear you way down!1st gear will become like a four wheel drive in lo range,itll be like your missing 5th gear once in top,i think they got the standard gearing spot on?i tried a 37 on a cb500 that have 34 stock,thats how it became I took it straight off,your going even and extra tooth,the 500s have 17x34 stock and the 550s have 17x37,they have a different internal primary reduction but have the same overall gearing.
Offline alacrity
  • Ride, Optimize, Repeat
« Reply #3 on: December 21, 2014, 02:59:06 PM »
i converted mine to 520.  A bit less weight. Plenty of strength.
Sprocket Specialties or
eventhgeardesigns@verizon.net
James Alfaro
7th Gear Designs
Optical Ignition Systems
Custom Sprockets
Custom Parts
Vintage Part reproductions
Shorai Battery Dealer
Offline mcgreens
« Reply #4 on: December 21, 2014, 06:05:06 PM »
Thanks for all the imput!
Offline DWS
  • Treat others as you would like to be treated .
« Reply #5 on: December 21, 2014, 07:15:44 PM »
Might help
Always looking for friends.
78CB750F3
PD 42A with original breadbox
4 into 1
valves adjusted to .003 (intake and exhaust) ( as was suggested for cooling )
slow jets#35 Main #110
 turned out to 1.5 some paper work says 1.75
4800 feet altitude
78 Honda CB 750 F3 Restoring now(Almost done)
BSA MX 50 Next
BSA b50T Parts
Offline MiGhost
  • What was that about being an
« Reply #6 on: December 21, 2014, 10:26:56 PM »
This it?
http://www.amazon.com/JT-Sprockets-JTR1493-41-SPROCKET-530-41/dp/B00CQKA39A
That sprocket will not work on the 550F. It is for a Kawi ZX\ZZ 06-later. Different mounting.
The design of the 550 hub will make it difficult to find anything other than a custom sprocket once you go past the stock 37 tooth.
~ Ghost
Grey Ghost '80 CB650C: Updated Stock Restomod. Period Custom Cruiser (OEM harbags & trunk, Wixom Ranger fairing, Jardine turnouts)
Bad Moon '83 XJ750MK Midnight Maxim: Full Dress Tour Deluxe w/ X-1 Fairing
Offline Blackfin5
« Reply #7 on: December 21, 2014, 11:12:14 PM »
Do not put the bike in gear until you bolt on the retainer clip correctly.  Then go to JT sprockets and get one for your yr and model 550.   I believe you can order a 35 to a 40 tooth.  As Dave said, unless you're racing 60ft, don't get a 41.  Way to buzzy.
Offline DWS
« Reply #8 on: December 21, 2014, 11:35:39 PM »
You can try cyclexchange.net also
78CB750F3
4 into 1
4800 feet altitude
BSA MX 50 Next
BSA b50T Parts
