Author Topic: Airbox Bowed Side.  (Read 820 times)
Offline jprochnow
Airbox Bowed Side.
« on: December 23, 2014, 08:19:57 AM »
I just went through cleaning up the stock airbox and join reassembly I found that the bottom section doesn't fully go into the top section and is actually bowing out. I have all the bolts and nuts tight but the side won't stay where it should. Anyone run into this before?
Offline youn6372
Re: Airbox Bowed Side.
« Reply #1 on: December 23, 2014, 10:58:15 AM »
Yes several times.  I think mine warped over time.  I ended up getting a new on on Ebay.
1973 CB750K
1982 CB900F
1983 VFR750
1983 CB1100F
1988 CBR1000F
Offline harisuluv
« Reply #2 on: December 23, 2014, 11:04:45 AM »
Yes this is a common warpage.  Use a heat gun on the bowed part, coax it straight and hold til it sets again. If heat gun is another available use a hair dryer. Results vary on your skill.
