Author Topic: CB750 K7 Cafe Racer Build  (Read 10983 times)
Offline Super Roo
Re: CB750 K7 Cafe Racer Build
« Reply #25 on: June 30, 2015, 07:04:05 AM »
Got the oil tank back from the welder.
I'm pretty impressed with the design and workmanship.
Now its off to the polishers along with the rocket cover.
Just waiting on the Rickman alloy tank I have ordered before I can finish the design of the rear seat and begin fibre glassing.
The weapon is starting to take shape.
Also attached the clip-ons and had a look at how the carbon fibre from mud guard looks!
Mean!!
Offline Super Roo
« Reply #26 on: August 27, 2015, 04:39:12 AM »
Bought a Rickman alloy tank from India of e bay.
Rocks up two weeks late, with a dent in the back of the tank.
Tested the tank on the bike and the length is 3 inches short and 1 inch short on the width.
Lucky I was able to dispute it and got money back.
Vendor didn't even want the tank back, not that's its any good for me!
Offline Super Roo
« Reply #27 on: August 27, 2015, 04:42:39 AM »
Test of how the front head light will look.
The band clamp holding the light into the metal shell is at the top and I'm concerned water will get into the light body.
To move it to the bottom I will need to cut a notch into the light casing to allow room for the clamp tightening mechanism.
Offline Super Roo
« Reply #28 on: August 27, 2015, 04:54:07 AM »
Finally got all of the engine parts machined.
* crank micro polished and balanced
* head ported
* new sleaves installed and honed to 915cc
Have started painting the engine parts.
Just have to get colour on the top and top and bottom cases and its time to bake.
Have to get moving on this beast as its almost spring and summer will be just around the corner!
« Last Edit: August 27, 2015, 05:01:02 AM by Super Roo »
Offline MessnerMoto
« Reply #29 on: August 27, 2015, 02:37:58 PM »
That Ducati front looks excellent. I like to see that someone is trying something different then GSXR or R1 forks conv... ;)
Offline Super Roo
« Reply #30 on: August 28, 2015, 05:56:09 AM »
Ducati forks are defiantly a lot beefier than Japanese.
Just praying they are long enough.
I am a little worried about the exhaust clearance.
Should have probably got a side winder exhaust to be safe but I already purchased a 4-2-1 race exhaust.
Offline Super Roo
« Reply #31 on: September 27, 2015, 11:52:30 AM »
After the issues with the crap India alloy tank have gone done the path of making my own fibre glass tank.
Starting with making the seat cowl and pan to get the skills up.
Made mould with refrigerator foam. Have finished sculpting now, just a little more detail required around the tank join.
I'm going to make the tank in two parts, a bottom and top.
After which I can mount all of my fittings on the inside and then join the two halves together.
I have a 1" joint around the two halves which is about 5mm recessed, so that a strip can be used to glass the two sections together and the join location will not be visible on the final tank.
I saw on-line that you coat the mould in duct tape. I used a plastic tape called 'duct tape' although this didn't agree with the resin and warps a bit. I recommend a layer of fibre reinforced duct tape with a cover of painters tape.
Have finished the seat pan. The crap duct tap has left deep ridges that I think I might sand a little. The seat cowl I used the paint tape and the result is much better.
Just have to get some chemical resistant resin for the tank and some microspheres.
« Last Edit: September 27, 2015, 11:59:39 AM by Super Roo »
Offline slikwilli420
  • Master of Disaster
« Reply #32 on: September 27, 2015, 01:22:33 PM »
Besides the dent is there anything else actually wrong with the tank?
« Reply #33 on: September 29, 2015, 08:16:06 AM »
And, be advised! Ethanol fuels will eat your fiberglass tank so a Caswell liner is required.
Ballsy move making your own fiberglass tank. Do not skimp on the fiberglass and as Cal recommended, use a Caswell liner.
Offline Super Roo
« Reply #34 on: January 19, 2018, 10:09:49 PM »
Bit of hard work, but finished the tank.
Made it in two parts.
Used wood jig to hold for joining.
Turned out reasonable.
Offline Super Roo
« Reply #35 on: January 19, 2018, 10:15:23 PM »
Worked out how to connect EFI throttle bodies to the engine.
First I ported the original rubber mount to suit the throttle bodies.
I ordered 2 90 deg bend silicon hoses that the rubber boots would fit inside and was the right ID for the throttle bodies.
I cut the hose to fit over the rubber boot and throttle bodies and used fuel resistant gasket to connect the two together.
Works a treat.
Offline JoeCooley
  • Long time lurker, but now I'm a
« Reply #36 on: January 20, 2018, 01:19:22 PM »
Nice work!
Joe in San Diego - Quick Cyles
78 CB750K 836cc Highway Racer - http://forums.sohc4.net/index.php/topic,162264.0.html
Rickman CR750 Restoration (SOLD)
Offline Super Roo
« Reply #37 on: February 02, 2018, 05:00:57 AM »
Painted the seat and tank.
Gloss black!
Tossing up if I want to put a gray pin stripe.
Painted myself as I was quoted $800 for paint which seemed steep.
Did tank many hours to smooth the fibre glass.
Dropped the seat pan off to get the seat cushion fabricated.
Should be ready in two weeks.
« Reply #38 on: February 02, 2018, 07:12:59 AM »
Want to sell the Indian Rickman tank? Im interested!!
« Reply #39 on: February 02, 2018, 09:37:48 AM »
Works a treat.
Hey another EFI bike! What throttle bodies are you using and what control system?
Offline Rnobx67
  • "failure is an option here."
« Reply #40 on: February 09, 2018, 06:28:26 AM »
Your work is amazing, the tank, woah !!!
« Reply #41 on: February 09, 2018, 06:48:04 AM »
Works a treat.
And which fuel pump?
Are you transplanting the fuel pump, throttle bodies, etc. from one bike platform or piecing it together.  I didn't see a cut-out for the fuel pump on your fiberglass tank.  Where are you installing it?
Offline Super Roo
« Reply #42 on: February 12, 2018, 06:32:36 AM »
The throttle bodies are gsxr 750 2008.
It's a complex system with many redundant systems that need to be removed.
I also had to get a gsxr wire harness to get all the wire clips.
The injector clips are denzo.
There are twin injections for each system, so 8 in total.
But they fire as one system, so basically one inject but set as two each side of the butterfly valve.
I have a Bosch fuel pump and an external fuel pressure regulator (aero with pressure gauge) returning fuel to the tank to keep it cool.
Fuel returns to the top of tank.
The controller is a micro squirt.
The fuel pump is way big but it doesn't need to be mounted inside the tank.
Got black anodised fittings and black nylon braided hose for the oil and fuel.
Not mounting the oxygen sensor in the exhaust as it's optional.
Offline Super Roo
« Reply #43 on: February 12, 2018, 06:36:11 AM »
Got the seat back from upholstery.
Does the job.
Memory foam and gel, should be cumfy as!
« Reply #44 on: February 12, 2018, 08:40:28 AM »
Wow! That's some work. I imagine that you've upgraded your charging system to something like Anders 32 amp system to feed the extra electrical demands.
Offline SKTP
« Reply #45 on: February 12, 2018, 11:53:06 AM »
SKILLZ! Looking amazing
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline Super Roo
« Reply #46 on: February 13, 2018, 01:13:51 AM »
I have the cycle x external charging system.
Makes the bike kick only, which will be interesting.
Considering I've increase note size.
But does reduce a few kilos in weight.
« Reply #47 on: February 13, 2018, 02:02:56 PM »
I just looked up the specs -- 16 amp system for either the internal or external Cycle X system.  Is the extra 3 amps enough to power the EFI/fuel pump?
