Hello, I'm refurbishing a set of carbs on my '73 CB750 and can not find an answer to a question I have about the throttle rod and the bracket that holds it in position on the throttle valve. The question is on the bracket opening. On two of the carbs the bracket is "open" and allows the throttle rod to move about 1/4" with spring pressure. On the other two carbs the bracket is closed down on the spring allowing no spring movement. Which is correct and is there a measurement on the opening of the bracket?
I hope I explained this well enough and I thank you for your help!!!
