Author Topic: Are these K0 Carbs?  (Read 1552 times)
Offline krusty
Are these K0 Carbs?
« on: December 31, 2014, 10:58:50 PM »
We have new next door neighbours in the process of moving in and it so happens they are bikers although their interest  is in Brit (Triumph, BSA) and US bikes (HD and a 1920s something Indian). Anyhow, about a week ago he came and tore down the old corrugated asbestos fence and disposed of it, correctly.
Today he was back to remove a little more of the asbestos he couldn't get to last time.
Just before he starts work on the fence he goes to his car and comes back with a rack of carbs and says "Here, take these". I ikmmediately saw they were CB750. At the time I was installing new guttering and didn't get a chance to ask where the rest of the bike was. No problem though.
Check the pics. Seem to be missing main jets. The low speed are #40s. Two brass floats have been replaced with plastic ones and, yeh, the rack is broke. I couldn't make out any nimbers on them. Nice and clean internally with nothing stuck or frozen.
So what do I have?
Have I been visited by Terry's fairy?
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Re: Are these K0 Carbs?
« Reply #1 on: December 31, 2014, 11:08:38 PM »
Yes KO carbs.
 Measure the choke arm, or show side shot with it folded down.
Check the tops for a number near the. Cable fitting, if it has it, it is cast in.
« Last Edit: December 31, 2014, 11:11:59 PM by 754 »
Offline goldarrow
  • one day, i'll be an
« Reply #2 on: December 31, 2014, 11:12:50 PM »
Those are the early K0 carbs alright.  Member here make and sell replacement mount rack
CB550 K0
« Reply #3 on: December 31, 2014, 11:57:20 PM »
 I welded one. Twice.  What does the choke arm length tell us?  I have a set from 1005511 a set from  10141xx and a set from 104xxxx i could check differences.
« Reply #4 on: January 01, 2015, 02:03:39 AM »
Early ones had longer choke arm.  And if they have a number 28 on the tops, it's your lucky day..
« Reply #5 on: January 01, 2015, 07:23:02 AM »
Yes, Harisluv makes one. Super lucky day, those are valuable.
« Reply #6 on: January 01, 2015, 08:13:34 AM »
Sometimes they are reasonable. I offered. Up a set here at 200 a few years back..no takers.
 I may split up a set to use 2 carbs on a 350 twin.  Did it before in the late 70,s.
« Reply #7 on: January 01, 2015, 08:32:48 AM »
Yes if they had the #28 tops it would be a very good start to the New Year for you.
Offline krusty
« Reply #8 on: January 01, 2015, 04:30:26 PM »
Still can't find any numbers anywhere. Nothing on the tops.
Checked the cables and found they have two different lengths. According to Hondaman's book these were the last of the K0s - assuming they are original, and they look it but that's not reliable. I'll have a shot at repairing the rack.
Here's the choke lever.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline harisuluv
« Reply #9 on: January 01, 2015, 05:43:16 PM »
The only number is on the top of the backplate.  It will say B750A.  They're identifiable just by looking at them, the number is just a formality, and it's not even on the carbs so it's a non-issue.
Choke lever looks like common version.
I do sell the backplates machined out of billet aluminum.  The backplate is commonly cracked just like yours.
Offline krusty
« Reply #10 on: January 01, 2015, 09:40:23 PM »
Thank you everyone for your input. In a nutshell I have K0 but not sandcast.
I think I'll do these up and put them away just in case. Ordered #115 mains from Yamiya today.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
« Reply #11 on: January 02, 2015, 05:59:39 AM »
Stock for those carbs I believe should be #120 on the mains.
Offline krusty
« Reply #12 on: January 02, 2015, 12:14:40 PM »
I was going by Hondamans book which mentioned #120 were stock for sandcast but the later "diecast" K0s, after 1970, they changed to #115.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline Guido56
« Reply #13 on: January 02, 2015, 01:10:06 PM »
According tables jets are 120.
I 120
When I was unloading 4 in 1 I rode the 132
Honda four 750 K1
Kawasaki Z1300 A3
Benelli TNT1130
« Reply #14 on: January 02, 2015, 02:17:58 PM »
Get a pic of the Indian. If you can..
« Reply #15 on: January 02, 2015, 02:26:57 PM »
I have seen Hondaman mention that but I have never bought anything with a #115 in it. Out of the 6 or more K1's or 1971 bikes for instance that I have bought even all of them had 120's which I believe is the suggested size for that year also.
Offline krusty
« Reply #16 on: January 02, 2015, 03:36:22 PM »
Will do. He hasn't moved his stuff yet so it could be a while due to his work commitments, possibly Feb or Mar. Poor bugger is downsizing from a 5 car garage to a 3 car. He says his dirt bikes will have to live outside.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline scunny
  • don't call me expert
« Reply #17 on: January 02, 2015, 04:45:14 PM »
[/quote]
[/quote]
the inhumanity of it
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline krusty
« Reply #18 on: January 02, 2015, 04:51:58 PM »
[/quote]
[/quote]
And the HiLux truck too.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline krusty
« Reply #19 on: January 03, 2015, 10:55:18 PM »
In one of the pics it shows two carbs with plastic floats. I would assume these came with brass floats. Would the plastic one have a different float height measurement? If so would they need to be adjusted using the clear tube method?
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline harisuluv
« Reply #20 on: January 04, 2015, 12:17:29 AM »
Brass are correct for the model, the synthetic ones are from a later model, but will still work fine and use the same setting: 26mm.
Using the clear tube method is up to you.
