Author Topic: tap sizes for these old fours  (Read 1460 times)
Offline fmctm1sw
« on: January 03, 2015, 08:05:08 AM »
I was looking for a tap and die set the other day at a local tool shop.  I didn't see much in the way of metric sizes there and I don't need the dies anyway.  So I got to looking around on Snap On's site and saw they sell them individually.  Best I can tell form working on these bikes, I really only need a few sizes:  M5-.8, M6-1.0, M8-1.25, M10-1.25 and 1.5, M12-1.5 and 1.75.
Is there really anything else I need other than those?
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
    • http://forums.sohc4.net/index.php?PHPSESSID=ou74qomol6enk6b2d940orqvm7&/topic,60973.0.html
Re: tap sizes for these old fours
« Reply #1 on: January 03, 2015, 08:10:56 AM »
this is standart metric..you vill nedd some fine thredet metric.for some frame/shoks mounts..and mirror mounts threds.
helicoils are fine for reparirs..but need their ovn taps..honda use some strange 7 mm. inside the engines.not the most used ,even in europa
« Last Edit: January 03, 2015, 08:13:25 AM by strynboen »
Offline fmctm1sw
« Reply #2 on: January 03, 2015, 08:25:21 AM »
I remember the mirror threads being weird and having a tough time finding a helicoil kit (locally).  M10-1.25 I think.  Yeah, I may invest in some good thread repair kits too.  I'm just tired of these cheap tools breaking...
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #3 on: January 03, 2015, 11:07:49 AM »
I would not get the taps at SnapOn..but they should be OK.
Decent quality are not that expensive.  KBC tools if near you should be way cheaper that SnapOn.
If you are not cutting new threads, machine taps would be OK.
« Reply #4 on: January 03, 2015, 11:21:34 AM »
M20x1.5 is the oil galley plug and oil filter bolt,  valve covers are M30 I think, oil tank are M22 and M24 or M26 and for idle set screw on old carbs you would need M6x.75.  But what you have will do I think.
Offline markb
  • When I finish my current project I might be a
« Reply #5 on: January 04, 2015, 08:22:20 AM »
There isn't an M10x1.5, M12x1.5 or M12x1.75 that I know of.  M12x1.0 is used for the rotor bolt and all the rest of the M12's are 1.25.  There are also some  M3x0.5, and M4x0.7 used on turn signals, handle bar controls, tail light, etc.  An M6x0.75 is only used for tappet adjusting screws and the rest of the M6's are 1.0,  The cam sprocket screws are an M7x1.0 and the connecting rod screws are an M7x0.75.  And yes the mirror thread is M10x1.25.
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
« Reply #6 on: January 04, 2015, 09:15:37 AM »
here are a cut of my metric standart..last kolonne are drill seise..its only the standart..not fine metric
klick to get it big...
12#1,75 is standart ,honda use finer threds
« Last Edit: January 04, 2015, 09:19:48 AM by strynboen »
Offline markb
« Reply #7 on: January 04, 2015, 12:46:13 PM »
There isn't an M10x1.5, M12x1.5 or M12x1.75 that I know of....
....on the Hondas.  And my knowledge is specifically the CB750.  It's certainly possible that some of the other sizes are used on other models.
« Reply #8 on: January 05, 2015, 04:44:25 AM »
Here is one more M6x0.75 for you - if you know what it is.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #9 on: January 05, 2015, 05:01:07 AM »
This "Thread Restorer" kit has served me well, for both Honda CB's as well as automotive purposes. Occasionally I'll need a tap here and there, so I'll pick up a single tap when needed:
http://www.sears.com/craftsman-48-pc-sae-metric-thread-restorer-kit/p-00942275000P?sid=IDx01192011x000001&kpid=00942275000&kispla=00942275000P&kpid=00942275000&mktRedirect=y
This kit actually has more metric tools than mine. I had purchased mine probably fifteen years ago and I think mine only has six metric tools instead of the ten shown with this kit.
Found it. This is the kit that I have, and it even costs more for fewer pieces!
http://www.sears.com/craftsman-40-pc-tap-and-die-set-master/p-00952105000P?prdNo=3&sellerId=SEARS
The thread restorer tools work for me in probably 95% of the problem fasteners I encounter. The other 5% either require Helicoil, fastener replacement, or both.
« Last Edit: January 05, 2015, 05:10:36 AM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
