Author Topic: 350f seat (lack of forethought)  (Read 5180 times)
pouchey
« on: October 08, 2006, 10:26:29 AM »
So I am sitting here with a 350f bike and a 500f seat. It fits just fine unless I put the pins in and then it is forward by a coule of inches. So I need advice.
Do I try to find someone who can move the bracket on the pan forward?
Do I try and find a 350 pan and transfer the foam and cover from the 500?
Do I find someone who wants to trade?
This is truly a bummer.
Offline heffay
Re: 350f seat (lack of forethought)
« Reply #1 on: October 08, 2006, 10:29:13 AM »
i would recommend option a or c
pouchey
« Reply #2 on: October 08, 2006, 10:53:16 AM »
Any suggestions on how I could move forward with option A ?  Has anyone here done it?
The seat looks great, only a few pin holes from a over zelous kitty. No appreciable sun damage. I am just not in the know on this stuff. Do I just find someone with welding equipment and see what they can do?
I don't assume there is any sort of conversion kit.
Offline Green550F
  • Nothing is as cool as that which you made.
« Reply #3 on: October 08, 2006, 11:05:10 AM »
If it is spot welded there is hope! You can drill out the welds and remount the brackets with rivets. That way you won't destroy the foam with heat!
93 Kawasaki Voyager XII
70 Honda CL350 Cafe
pouchey
« Reply #4 on: October 08, 2006, 11:07:36 AM »
Is this not a JB Weld kind of situation?
Offline heffay
« Reply #5 on: October 08, 2006, 11:10:31 AM »
probably not... i'd agree with the rivet idea though.  should be pretty simple.
pouchey
« Reply #6 on: October 08, 2006, 11:18:28 AM »
what kind of place would I call to find someone with a riveter?
Hey, I gotta start somewhere . . .
Offline Green550F
« Reply #7 on: October 08, 2006, 11:25:54 AM »
Any hardware store or even Wal-mart would carry one.
70 Honda CL350 Cafe
Offline heffay
« Reply #8 on: October 08, 2006, 12:21:23 PM »
get a decent one with a number of different size rivets.  or make sure you know what size rivets you need.  a rental place may have one to rent but i doubt it.
good luck
Offline Kevin400F
« Reply #9 on: October 08, 2006, 01:15:17 PM »
The hinge and the latch piece are both bolted to the seat pan.  Just unbolt the bracket and latch piece and set the seat in place to check fit.  I think you'll notice the underside of the 500F seat is not a real good fit to the 350F frame, and the rear rubber bumper misses the frame loop by about an inch, height-wise.  The front rubber bumpers on the 500F pan are intended to sit on the round frame rails and are spaced about 3/4 inch too wide for the 350F frame, etc., etc.   The 500F uses a different latch design than the 350F.   The distance between the hinge pins and latch piece are about an inch wider on the 500F than the on the 350F.  I don't think the upholstery swap will work very well, since the 500F seat is about 2" longer than a 350F seat.   Good luck.
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #10 on: October 08, 2006, 01:33:51 PM »
It looks like the answer is eBay it and look out for a 350 seat.
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
pouchey
« Reply #11 on: October 08, 2006, 01:39:49 PM »
I know Steve, that was the answer I dreaded to hear. And here I was thinking I could get through this without a whole lot of thinking.
pouchey
« Reply #12 on: October 08, 2006, 01:43:11 PM »
Since it is now abundantly clear that there is no model compatability on these things, how about year compatability? Anybody? It would drastically help my ebay searches.
    • TVAM
« Reply #13 on: October 08, 2006, 01:45:25 PM »
I don't think that there were any differences between the 350s.
How is the 500 seat and does it have the strap? (mine doesn't)
SOHC4 Member #2393
2015 Tiger 800 XRT
pouchey
« Reply #14 on: October 08, 2006, 01:50:09 PM »
Email comin your way Steve
pouchey
« Reply #15 on: October 08, 2006, 04:38:37 PM »
has anyone put a 73 0n a 72?
Offline Kevin400F
« Reply #16 on: October 08, 2006, 04:44:13 PM »
The seats are identical for all CB350Fs, regardless of year.
Kevin
pouchey
« Reply #17 on: October 08, 2006, 04:56:34 PM »
I am prepared to go with that Kev, Anyone second??? Is that for 350 and 350f?????
Offline Kevin400F
« Reply #18 on: October 08, 2006, 05:05:51 PM »
A seat from any year CB350F four-cylinder will fit on any other year CB350F four-cylinder.
pouchey
« Reply #19 on: October 08, 2006, 05:36:16 PM »
So are we for sure on the fact that the 350 is a no go on the 350f????
Offline Green550F
« Reply #20 on: October 08, 2006, 05:53:36 PM »
The 350(twin) and the 350F are as compatible as mounting a Yamaha seat. Sorry.
70 Honda CL350 Cafe
pouchey
« Reply #21 on: October 08, 2006, 05:58:29 PM »
this is a bummer man . . .
I guess the best part is, someone may be lookin for the 5 hundi seat and I can make a few bux back (notice my extensive use of modern forum speak [I am myself impresed]).
pouchey
« Reply #22 on: October 08, 2006, 08:23:02 PM »
ahhhhhhhhhhhhhhhhhh!!!!!
Was it one of you guys who just out bid me on that damn seat??
pouchey
« Reply #23 on: October 09, 2006, 07:56:51 AM »
Offline wardmoto
« Reply #24 on: October 09, 2006, 09:41:46 AM »
I have a sweet 350F seat with good vinyl and foam looking for a home...
03 Suzuki SV 1000S
86 Suzuki GS 550ES
72 Honda CB 350K
72 Honda CB 350F
72 Honda Cb 350F cafe
