Author Topic: getting younger sibbling to cb550k - a xl250  (Read 5034 times)
Offline cb550fnewb
« on: January 06, 2015, 06:53:03 PM »
This weekend I will picking up a 1976 xl250 from a friend for $350.  Its running just needs some attention to an oil leak and apparent none of the lights are currently working, hoping fuse or batt issue. Will make a nice addition to my 76 cb550k for the rough roads here in southern utah.
Photos to come hoping it will be as reliable as my cb550 and road worth for safety inspection before spring.
Online seanbarney41
Re: getting younger sibbling to cb550k - a xl250
« Reply #1 on: January 06, 2015, 08:04:07 PM »
cool, I wouldn't mind finding an older one.  Be sure and post pics.
Offline scunny
  • don't call me expert
« Reply #2 on: January 06, 2015, 10:59:20 PM »
that would be a motorsport then. + 1 on the pics
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline cb550fnewb
« Reply #3 on: January 07, 2015, 11:12:50 AM »
here is the only picture i have seen of it.  It is over 2 hours away and all that matters to me is it runs and stops and has a title.
I did not realize it was motorsport.  She does not no much about it other than it runs and leaks a little oil.  Would guess that she could be wrong on the year.  I do not know too much about them so one picture does tell me much about year/motorsport or not.
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #4 on: January 07, 2015, 03:00:43 PM »
HEY! Note that the '76 XL250 was a one-year model. The frame, exhaust & head are different on the earlier ones, there wasn't a '77 model in the States, and in '78 they moved to a dual-header exhaust. A lot of the parts won't swap over. Not saying don't buy it, but I just went through this last year (read about it here: http://forums.sohc4.net/index.php?topic=132256.0) and wanted to give you a heads-up. Good luck!
Offline cb550fnewb
« Reply #5 on: January 07, 2015, 06:48:02 PM »
That is good to know. I think I will still go with this one since its from a trusted friend and think price is resemble.  I am mainly looking to reduce wear to my 4x4 truck this summer.  If i get it to run reliable and pass inspection, I will run through the summer and may resell it come next winter since I am a seasonal employee and only have room for the cb550 in my trailer (and it was given to me by my father-in-law so it is here to stay).
I have one question if anyone can chime in:  My understanding is the bike has a small battery to operate.  If the battery is bad or low can it cause the bike to operate fine but the lights (all of them) not function at all.  The bike as no lights working.
« Reply #6 on: January 07, 2015, 09:02:54 PM »
As far as I know they stayed in 72 or73. As with the 350. Up to 76 or so was side port,  single pipe. Then they changed to twin pipes.. And call them center port.
 If it has the stock exhaust shield it say Motorsport on it.
Offline becken
« Reply #7 on: January 08, 2015, 06:33:05 AM »
My second bike was a 72 or 73 xl250, all silver, bought new. I loved that bike. The battery was just there to run the lights and could be easily removed with a quick disconnect. The headlight had its own coil in the alternator and ran on alternating current. I'm not sure if any of that was changed on the 76.
1976 CB550F bought new
1981 CM400A wife bought new
2004 GL1800
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #8 on: January 08, 2015, 10:28:04 AM »
It has three coils in the alternator: one runs the ignition, one runs the headlight and the other charges the battery (which runs the tail/brake light & turn signals). The bike will run without a battery, but you'll have no tail/brake lights or signals. No biggie if you're in the woods tho.
Offline tbpmusic
« Reply #9 on: January 08, 2015, 10:35:18 AM »
You'll like it - great for Southern Utah (where exactly??).
Kick start with clutch pulled in like a real dirt bike, some gruntage because it's a single, good power-slider too. Play with the sprockets to get what you want.
Sadly, it's a 6-volt system, so that was always a PIB even when new.
The bike shares nothing with the SL series, and that's good.
Bill Lane
Offline cb550fnewb
« Reply #10 on: January 08, 2015, 12:18:49 PM »
The light have to work for the inspection so hoping I can get the lights functions even if it is just for a day
Offline cb550fnewb
« Reply #11 on: January 08, 2015, 12:23:05 PM »
I live/work in Capitol Reef NP. I do not have any experience on dirt bikes so any off-roading will be pretty mild to ATV roads on the Forest Service.
« Reply #12 on: January 08, 2015, 01:18:38 PM »
Iwas wrong does not say Motorsport on the pipe.. At least the one I have.
Offline cb550fnewb
« Reply #13 on: January 08, 2015, 02:35:43 PM »
Pictures to come Saturday as long as she locates the title in time.  Hopefully the trouble shooting will be easy to get it registered by spring.
Offline tbpmusic
« Reply #14 on: January 09, 2015, 10:49:02 AM »
I used to hang out in the Kanab area quite a bit, I love that country.......if I could have found work, I'd have moved there decades ago. Not many jobs for a chemist, though.
This will be a great bike for your application......enjoy.
Bill Lane
Offline cb550fnewb
« Reply #15 on: January 11, 2015, 02:14:02 PM »
Got it and now need help.
I got the bike to start after some effort and fresh gas. I let it warm up and I could not turn of choke or it would die. Finally it die and I could not get it to start again so I took apart the carb and found that the main set was completely plugged.  After air compressor and soaking in brake cleaner I finally got it opened up and reassembled everything.
Still could not get it to start back up and noticed the cap on the spark plug and the wire did not look very good, so I trimmed it and took a cap and plug off my cb500 (same exact plug that was in it).  It fired right up.
I then let it idle 5 minutes (would only get down to 4000 rpms but I figured I would take it for a ride and make sure the transmission was function correctly before worrying about anything else.  Stalled and would not start.
Not sure what is going on.  Am I correct to think that the coil packs could be getting warm then failing to give spark?  I am going to try and start it again in a few minutes and see if it will start after cooling.
Any ideas on what to check? I am getting gas for sure.
Offline cb550fnewb
« Reply #16 on: January 11, 2015, 03:52:18 PM »
I cannot get it to start at all and appears to not have spark.  I am having trouble kicking and looking at the spark plug for a spark by myself.
Also while checking the points alignment,  I noticed oil in with the generator under the cover.  Am I right that oil should not be in that compartment?  Looked like if you laid the bike on its side that oil could flow into it so I am not sure if I have a leak or it was laying on its side.
Anyways I can not get it to start at all what should I check next?
I thought about putting another new spark plug in it and see if it will start which I might try tomorrow if the weather is decent.  Could the bike be fouling them enough to stop it from starting from being to rich?  Spark plug looked brown and wet when I took it out.
« Reply #17 on: January 11, 2015, 06:05:12 PM »
Does the bike have a battery? If so, check the voltage and/or recharge it.
Offline cb550fnewb
« Reply #18 on: January 11, 2015, 06:24:21 PM »
It has a battery that is dead.  Will this have an affect on starting it?  Your suppose to be able to drop the lights and battery and just kick it but if it will give me a little more spark might help.
« Reply #19 on: January 11, 2015, 06:32:55 PM »
Yeah, the battery might give it more spark, but try turning the switch to lights on with the headlight unplugged and see how it starts. I had a '66 C200 that the battery would gradually go dead, and hitting the horn or rear brake would kill the motor: when this happened, I would head for home and charge the battery. I finally figured out that all I had to do was switch the lights on, which kicked in an extra coil in the alternator to provide extra power.
Offline cb550fnewb
« Reply #20 on: January 11, 2015, 07:12:48 PM »
Okay I will try that.  Right now I have my carb in pieces and my needle is set to the highest groove.  Which I think is the leanest option.  3rd is stock and usually a little rich (plus I am at 5600ft) so I switch it to the 4th from the bottom to be closer to factory.  I will charge the battery tomorrow and try turning the head light on with it unplugged.
If I can get it started again I will mess with the idle and mixture screws to see if I can get it to keep running.  I am thinking that someone has messed with the carb a bit with the needle moved to leanest and the fact that I could start it with a blocked main jet.
Think spark is the current problem.
Also idle screw was out over 2 turns so I tighten it up to the factory 1 1/4.
« Last Edit: January 11, 2015, 07:57:16 PM by cb550fnewb »
« Reply #21 on: January 11, 2015, 08:33:48 PM »
If the battery is gone, usually starts fine, mine does . If idle circuit is dirty , always willbstart harder unless you prime it. But you know it runs so its probably ok.  Are both cables on the carb, should be able to get lower idle.
Offline cb550fnewb
« Reply #22 on: January 11, 2015, 08:49:12 PM »
First time I got it running I let it run for 5 minutes (it was about 40 degrees here) and I could not put the choke in without it stalling.  I don't remember the RPMs being very high for being choked.
After cleaning the carb, it would only run with the choke off and +half throttle.  It ran for 10 minutes at 4000 rpms and I tried to take it for a ride and died as soon as I let the clutch out.  I then pulled the spark plug/cap and replaced it with an used one from my cb550 and it started right back up and died the same as above.
I now have carb set back to factory settings and cleaned the air filter.  I will reassemble after a morning duck hunt tomorrow.  Unfortunately, I do not have a garage and my cb550 is filling my trailer so I am working on it in the driveway.
Can you guys confirm that you can get oil in the generator area by laying the bike on its side or should i be looking for a leak?  There was about a 1 1/2 quarts in there when I took off the housing around the generator to drain the oil.  Previous owner laid the bike down a lot while riding.
Offline cb550fnewb
« Reply #23 on: January 12, 2015, 04:22:32 PM »
Not sure if you can see but the photo is a spark plug that was in bike for 5 minutes running.  Appears way to rich after putting carb back close to stock (I put the clip 1 up on the side of lean for the needle) bike will not start at all.  I checked float level before reassembly and seems fine maybe a little on the lean side.
What should I do next was thinking to order a rebuild kit for the carb since I can not lean it out any more.  I believe air is getting in and tried to start it without air filter just encase and still could not get it to start. Hoping maybe one of my jets was drilled out or something
I can see the plug spark but not sure how reliable they are firing while kicking.
Offline DustyRags
  • I'm not skilled, I'm just a
  • Just try it and see what happens
« Reply #24 on: January 16, 2015, 04:48:55 PM »
What's the idle screw doing?
1976 CB550K- sold
2005 Kawasaki Vulcan 500- sold
2000 CB750 Nighthawk - sold
1975 XL350 - crashed
2004 Suzuki Vstrom 650 - sold
