Author Topic: carb float thingy  (Read 1132 times)
Manny
carb float thingy
« on: October 08, 2006, 11:10:48 AM »
What is the piece under the float on the left carb (#3)? The right carb (#2) is missing it. I'm guessing it helps regulate float height, but how important is it?
I actually took apart the carbs thinking that the #3 was leaking because the floats were sticking. I opened the #2 just to have something to compare it to.
edit: I also notice that the gold post/jet thingys are in different positions on the bottom of the carb, next to the floats. Is this a symmetry thing as they are at the center line of the bike? or is this a problem?
Thanks.
« Last Edit: October 08, 2006, 11:30:25 AM by Manny »
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
Re: carb float thingy
« Reply #1 on: October 08, 2006, 11:41:35 AM »
It is a piece of spring steel, when the float bowl is fitted it puts pressure on the main jet to stop it falling out, It is therefor quite important, but if it hasn't fallen out yet then????
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
Offline number13
  • 1973 CB500, 2002 VT750DC
    • Sound Exchange
« Reply #2 on: October 08, 2006, 03:06:55 PM »
Those are your low speed jets, they are just fine where they are.
Bikes parked out front mean good chicken-fried steak inside.
Manny
« Reply #3 on: October 08, 2006, 03:29:52 PM »
Sweet, thanks. Found the piece and put it back in. It must have fallen out when I took the bowl off.  :-[ It all works now, though. So  ;D .
