Author Topic: Fork Spring Question  (Read 1339 times)
Offline Kustomizer
« on: January 13, 2015, 08:23:52 PM »
I'm in the process of tearing my front forks on my cb750 apart and the springs are 18 5/8th" long and I was wondering if these were within tolerance to keep using?
Offline scunny
  • don't call me expert
Re: Fork Spring Question
« Reply #1 on: January 13, 2015, 11:40:36 PM »
there are manuals available on here, just down load yours. sorry I can't give you specs, I ride a 650
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Wobbly
« Reply #2 on: January 14, 2015, 01:02:28 AM »
If it is a K7/K8, they need to be replaced (service limit 19 1/2 in or 495.0 mm). I don't know about the earlier models.
Offline oldhatt45
  • The person called in at the last minute to share the blame is the...
  • Just an Old Guy that's gone to the Dogs
« Reply #3 on: January 14, 2015, 06:42:07 PM »
Kustomizer,
I recently replaced my fork springs (1976 CB750 K6).
I put in the Progressive fork springs (progressive rate) that came with a PVC spacer.
If I recall correctly, the springs were around that 18 5/8 length dimension.
Once you add the PVC spacer you're right around the 19 1/2 inch dimension that Wobbly quoted.
I'd have to go dig out the paperwork, but I'm pretty sure I'm right.
What I would check is are your current springs "progressive rate"?  If so they are not in all likelihood original, and probably should have spacers.  If they are not "progressive rate" springs, then it may be more difficult to figure out if they were replacement springs that should have had a spacer or springs that have collapsed over time.
I know this is not much help, but a few things to check.
Charlie
Offline bjbuchanan
« Reply #4 on: January 14, 2015, 07:07:34 PM »
They are probably saggy originals
You can't compare aftermarket sizes even with preload spacers because preload spacer is dependent upon the actual spring rates and free lengths. The length being near stock can be totally coincidental
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #5 on: January 15, 2015, 05:58:52 AM »
Serviceable limit is 18.11" for up to K6, yours are 18.625". Getting sloppy! Time to upgrade!
« Last Edit: January 15, 2015, 09:08:57 AM by evanphi »
--Evan
1975 CB750K "Rhonda"
Wobbly
« Reply #6 on: January 15, 2015, 08:35:41 AM »
Serviceable limit is 18.11",
Definitely not for the K7/K8
Offline evanphi
  • Apparently I'm an
« Reply #7 on: January 15, 2015, 09:09:14 AM »
edited mine. :D
--Evan
Offline Kustomizer
« Reply #8 on: January 15, 2015, 09:53:00 AM »
Thanks for the info!
« Reply #9 on: January 15, 2015, 12:00:17 PM »
Progressive springs and correct amount of oil, see attachment in this thread.
http://forums.sohc4.net/index.php?topic=144208.msg1641369#msg1641369
