Author Topic: GV1390's Trattoria "Racer" V2!  (Read 74352 times)
Offline Trad
Re: GV1390's Trattoria "Racer" round 2!
« Reply #50 on: February 19, 2015, 08:09:56 AM »
Thanks!
Well I've been second guessing leaving the head bare for asthetic reasons only. I agree, I hate the thought of stuff chipping. I just think it'll look odd going from silver block -> wrinkle black jugs -> bare head -> powder-coated hyper black valve cover.
eh? Maybe it'll look good? I'm over analyzing as usual, ha.
As long as the pieces are clean I think It'll all look good. haha. Anything is better than an old chipped up and corroded engine. It'll look fresh regardless of the colour combo. My vote is to leave it as is.
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
Offline Trad
« Reply #51 on: February 19, 2015, 08:10:51 AM »
Thanks!
Whatever works for you is cool. Another thing you might think about is clean up. In the "unlikely" occurrence that you have a valve cover leak, cleaning a coated surface is much easier than bare metal.
This is true, can't argue that.  ;D
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #52 on: February 19, 2015, 08:34:49 AM »
GV... sorry to change the subject, but I see you got a carb heat shield from MotoGP Werks.  Chris also threw one in with my 550 exhaust.  Have you used one of these before?  I'm curious how the shield may affect jetting.  Will I have to jet richer since the air is cooler/denser?  Or are the affects so minimal it won't make a difference?
Also, I've noticed guys that run these on race bikes have a rubber trim around theirs to help keep the materials mated.  (picture attached) Is this something I should consider doing?
If anybody has pictures of a heat shield installed on their SOHC, I would love to see it!  Thanks in advance, and sorry for the hijack!
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline calj737
  • I refuse...
« Reply #53 on: February 19, 2015, 09:15:56 AM »
Not the best idea to support the motor by the exhaust studs there, Chief.
Offline GV1390
  • Express Gratitude.
« Reply #54 on: February 19, 2015, 09:38:19 AM »
I knew you'd say that, glad I'm not using that head though! ha.
93' GSX-R1100, 78' CB550, 71' CL350, 71’ CB500 & 02' ZRX1200R.
Offline GV1390
« Reply #55 on: February 19, 2015, 09:40:07 AM »
No offense taken.
I'm not sure exactly how effective the heat shields are, I've never seen them on CB's until he included one truthfully. As far as jetting is concerned, that's something as with any modification will need to be tested on the actual bike with the mods, hence why these are a million different threads with different size jets on everything.
Offline joeyvans
  • Definitely not a
« Reply #56 on: February 19, 2015, 11:55:17 AM »
I knew YOU'd say that, and I agree. Never know until you tear into it.  Are you going to use yours? Any thoughts on the rubber trim idea?
1976 CB550 K2
Offline GV1390
« Reply #57 on: February 19, 2015, 12:20:26 PM »
Yes I will be using mine. The rubber doesn't look bad, I'd probably figure something of some sort out but won't know until I get there, haha.
Offline joeyvans
  • Definitely not a
« Reply #58 on: February 19, 2015, 12:25:19 PM »
You mean to tell me the heat shield isn't at the top of your priority list? Shame! Kidding... Keep up the good work. Looks great so far!
1976 CB550 K2
Offline GV1390
« Reply #59 on: February 19, 2015, 12:28:15 PM »
Thank you!
Offline GV1390
« Reply #60 on: February 20, 2015, 09:48:47 AM »
All the pieces I had coated in one picture:
Engine is getting paint tonight, tires will be mounted on Sunday. Woot woot.
Offline wynston
« Reply #61 on: February 20, 2015, 10:44:49 AM »
Looking real good!
Offline GV1390
« Reply #62 on: February 23, 2015, 05:47:49 AM »
Thanks!
Short block got some paint, not bad for a rattle can "hodge-podge" job.
Mounted the tires with some help from Nick:
Test fit the seat and tank combo for the first time with the rubber mounts in, pretty nice fitment:
My powder-coated pieces should be in tomorrow. Then I have to find some new rings hopefully today and order them, hone the jugs and start the final assembly of the long block.
Offline Trad
« Reply #63 on: February 23, 2015, 08:56:43 AM »
Looking killer G! Glad you found some STD piston rings too. This thing is going to be dialled.
Offline GV1390
« Reply #64 on: March 10, 2015, 07:13:02 AM »
Not much of an update as I recently picked up another project....but the bike will get done before I start it anyway...
Ran into some issues with paint on my short block....some of the paint flaked off, the only thing I can think of is, I used self etching primer BUT from my understanding you're supposed to let it dry for 30mins then apply your paint. I let the primer sit for a week then I scuffed it with a scotch-brite pad, cleaned it and sprayed on top.
Anyone have any suggestions? I really don't want to re-blast the entire thing especially because in all other areas it looks solid.
Other project I spoke of:
Offline calj737
  • I refuse...
« Reply #65 on: March 10, 2015, 07:34:51 AM »
flaking paint is a symptom of poor adhesion. If the paint and primer are both flaking, then your primer did not adhere to the block. It sounds as though you did not degrease properly the engine block.
Start over.
« Reply #66 on: March 10, 2015, 07:56:28 AM »
You cannot clean the surface of the bare metal enough before primer and paint. Sorry to tell you, but I agree with Cal. Start over.
Offline GV1390
« Reply #67 on: March 10, 2015, 08:14:26 AM »
Yeah not sure how to clean out 40 years of grime from every pore in the aluminum. I cleaned and cleaned and cleaned. I am also thinking that the temps were too cold for it to adhere properly.
Offline calj737
  • I refuse...
« Reply #68 on: March 10, 2015, 08:42:59 AM »
Is the paint separating R from the primer, or the primer and paint from the aluminum?
Offline Trad
« Reply #69 on: March 10, 2015, 08:43:39 AM »
Just leave it chipped. It adds character. :P
« Reply #70 on: March 10, 2015, 09:20:33 AM »
I'm not sure about temperature, but as for cleaning, you should use acetone to wipe each surface just prior to paint.  As for prep, if the motor is fully disassembled, you can blast it with soda, glass/plastic beads or sand.  If the motor is not fully disassembled, scrub it with Simple Green and a wire brush and green Scotch Brite pads.  It sucks doing it the manual way.
Offline GV1390
« Reply #71 on: March 12, 2015, 06:32:14 AM »
I am in the process of soda blasting it AGAIN.
I didn't want to tear down the short block so I added the spare jug/head I had laying around to blast it. I used acetone to clean it the first time. Hopefully this time will be my last with some extra attention to detail. I do think the temps in my shop were deff too cold though.
Offline calj737
  • I refuse...
« Reply #72 on: March 12, 2015, 06:43:11 AM »
Hope you use acetone to clean it after soda blasting.
Offline GV1390
« Reply #73 on: March 12, 2015, 06:44:47 AM »
I actually spray paint while soda blasting, it's a good look.
Offline callmejarob
« Reply #74 on: March 12, 2015, 08:54:42 AM »
Same thing happened to me when I soda blasted and painted my engine, and I took every damn precaution I could, cleaned it several times with soapy water and acetone and it STILL flaked.  I ended up just getting the engine vapor blasted.
