A little update for those interested....
I made the seat bracket and tabs, had a friend weld on the tabs for me.
A few crappy iPhone pics:
Ditched the exhaust setup as I'll be running a Ripple Rock Racers Hindle setup from my buddy Kemp.
Still have the following to do:
*Fabricate a rear ventilated aluminum panel under my seat cowl for R&R placement
*Complete wiring harness from scratch with supporting diagram
*New triple trees with corrected offset - which means new holes for indicators, re-make an ignition switch bracket and also add turning stops
*Decide what tank emblems to run
*Address kick start lever issue as it interferes with my rear brake rearset
*Finish the front portion of my seat mounting
*Clutch cable
*Make a rear tire hugger "fender"
*Bleed front brake, add fluids, double and triple check all bolts, adjust valves, etc
Kinda torn if I want to run a 1/4 or 1/2 fairing....I don't in a way as that's the typical Cafe Racer theme and also because I don't want to take away from the awesome headlight I'm running. Maybe I'll use that as an excuse to build my other CB550F.
