Author Topic: Switch and throttle removal help  (Read 1347 times)
Offline B-EZ
« on: January 16, 2015, 02:11:28 PM »
I'm trying to replace my handlebars... How do I remove the throttle and the start switch? The switch is just the two screws on the bottom and pull the wires through the bars, correct? Thanks. I looked in the manuals but didn't see any specifics. Also searched but didn't find anything...
Offline B-EZ
Re: Switch and throttle removal help
« Reply #1 on: January 16, 2015, 02:24:37 PM »
75 CB750K if that matters
Offline bjbuchanan
« Reply #2 on: January 16, 2015, 02:49:02 PM »
Two screws and they come apart. They are like a clamshell. Then alternately tug and push the wires out
Pull by the wires not the switch so you don't damage the switch internals
Offline B-EZ
« Reply #3 on: January 16, 2015, 02:56:41 PM »
Is there a trick or an easy way to disconnect the throttle cable from the throttle control?
« Last Edit: January 16, 2015, 08:19:40 PM by B-EZ »
Offline bjbuchanan
« Reply #4 on: January 16, 2015, 09:43:55 PM »
Disconnect the cables from the carbs, it will be really obvious then. You will have tons of free play. No magic, just what you see. Nuts and bolts
Offline B-EZ
« Reply #5 on: January 17, 2015, 07:59:54 PM »
Thanks. Got the cables disconnected but the wires are giving me a lot of trouble. After 30+ mins pulling/pushing I think the wires have moved less than an inch and I broke one at the switch
Offline mrfish2
  • I might be a
« Reply #6 on: January 17, 2015, 09:04:06 PM »
Spray some WD40 inside those bars and get a second pair of hands, makes things loads easier.
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
