There's a pretty big cavity behind those bearings, and any goo you force in there with solvents or air is likely to end up in there. I was previously cautioned about spinning a dry bearing with compressed air, was told it can damage it. If you do this, it will spin at pretty high speed.
You don't pack wheel bearings, half full only. If they are full the grease can churn and break down. If you get them pretty well cleaned out then use a clean popsicle stick to fill the half you can access, turn the bearing some to distribute the grease and call it good. Pack steering head bearings for sure, but not wheels.
I might try flushing them from below over a pan so the spooge runs back down and not into the wheel, if you're set on trying this. But if it were me I'd just replace them with new.
