Author Topic: cb500 not charging and I ran out of beer.  (Read 1615 times)
Offline vonvendetta
« on: January 25, 2015, 05:16:06 PM »
I have a rick's Motorsport Reg/Rec combo, shorai battery and new wiring.
I drove it two days ago for about 45 minutes. Bike died and battery wasn't doing well. Pushed bike about 4 miles home which sucked! Charged and I am about full again.   :'( :'(
I have been reading posts for about 3 hours now and am just drawing a blank. It's like right before I started tackling the wiring, it seemed very overwhelming until I started. I just need some help on what to check next. Why is there not an info-graphic for THIS!!
I checked that there is continuity between all the wires and connection.
1.) Can I just connect the voltmeter to the red wire coming out of the reg/rec to test voltage? This wire I currently have running to the starter solenoid.
1.5.) If there is no voltage then test alternator?
2.) Is there a way to test that the alternator is spitting out what it should? (the white wire?)
I am just brain dead and need guidance.  :o :-\
Video to show that when giving gas the volts drop. From what I understand, they should be going up. While running it sits at 12.6 and while off it is at 13.4
« Last Edit: January 25, 2015, 05:45:27 PM by vonvendetta »
Re: cb500 not charging and I ran out of beer.
« Reply #1 on: January 25, 2015, 10:13:48 PM »
Sounds like some short open pipes, or a boat header.  I can't help with the wiring but I have some beer, come on over.
Offline faux fiddy
  • bike in a box
« Reply #2 on: January 26, 2015, 12:41:40 AM »
Start eliminating  non essential circuits that could have failed or shoredt. Keep the ones you need to run hooked up. Disconect lights , horn, blinkers etc.  with your meter hooked up and bike running and see if the readings show any one circuit causing the drawdown.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline vonvendetta
« Reply #3 on: January 26, 2015, 06:19:15 AM »
That is a huge help on where to get started. I'll run the red directly and make sure I ran the black correctly and test tonight.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #4 on: January 27, 2015, 12:55:51 PM »
Here follow this diagnosis, it's an easy to follow process of elimination.
http://www.oregonmotorcycleparts.com/FAQ.html
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
« Reply #5 on: January 27, 2015, 01:16:35 PM »
I would be extremely worried about running out of beer..!!!  what else did you say.....?  8)
Offline vonvendetta
« Reply #6 on: January 27, 2015, 02:22:30 PM »
I forgot?!?
« Reply #7 on: January 27, 2015, 02:28:48 PM »
 ;D ;D
« Reply #8 on: January 27, 2015, 06:59:42 PM »
That is the first issue that needs to be rectified. (Pun intended).
« Reply #9 on: January 27, 2015, 08:08:20 PM »
nice... :P
Offline vonvendetta
« Reply #10 on: January 28, 2015, 07:28:34 PM »
I connected the red wire directly to battery just now and am getting an increase instead of decrease. Running some tests this weekend to make sure I'm in the correct ranges.
Offline 750cafe
« Reply #11 on: January 28, 2015, 08:04:37 PM »
But, most importantly, did you ever get more beer?
Eric
Is there anything more fun than riding? They are between your legs and are quiet when you turn them off.
« Reply #12 on: January 28, 2015, 08:10:07 PM »
Must have, voltage is on the rise!
Offline 750cafe
« Reply #13 on: January 28, 2015, 08:36:42 PM »
Electrolytes in beer?   ???
Eric
Offline vonvendetta
« Reply #14 on: January 31, 2015, 01:49:46 PM »
So here I am again....
Willing to give two gallons of beer to whom ever fixes this?
So I've run the red directly to battery, black to a hot running from her switch and I still don't get a charge.
It drops steady and rpms don't change it.
If I check the red from reg/rec I'm getting an odd .60 volts, video attached. Is there a way to check of the stator puts out 14.5v? I'm thinking that maybe my combo rec/reg isn't working as should.
« Last Edit: January 31, 2015, 01:52:51 PM by vonvendetta »
Offline vonvendetta
« Reply #15 on: January 31, 2015, 02:25:48 PM »
Did this test and the negative board isn't responding:) :'((((
« Reply #16 on: January 31, 2015, 05:44:29 PM »
Your meter is not  connected correctly....
Offline vonvendetta
« Reply #17 on: February 01, 2015, 01:35:21 PM »
Does this look correct? I think I might have fixed it now.
Offline vonvendetta
« Reply #18 on: February 01, 2015, 06:33:00 PM »
So after all that crap I went for a test drive and the battery is charged more than when I started the ride. I have wasted countless hours due to a horrible wiring harness that I bought from sparkmoto. I am not one for vendor shaming but this harness had the worst quality wiring (very few strands that you were able to just pull out, my cheap $20 order from ebay had better wiring), 3.9mm bullet connectors vs 3.5mm standard Honda size, nothing was soldered and horribly crimped; for the price I should have received a better product. I was hoping that by paying a company like that I would 1. support a small business and 2. get it done correctly. If anyone is considering them, please use caution. Nothing is worse than trying pinpoint which leads are bad on a brand new harness which there were SIX!
Thank you all for your help and patience!
« Last Edit: February 01, 2015, 06:36:56 PM by vonvendetta »
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #19 on: February 03, 2015, 01:30:32 PM »
DING! DING! DING! Looks like you get some beer delivered to you!  ;D
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
