Author Topic: Mystery Coil  (Read 605 times)
Offline krusty
Mystery Coil
« on: January 26, 2015, 02:50:53 AM »
Here's some pics of a coil picked up at a garage sale. No markings on it to indicate a manufacturer. I've never seen another like it, looks kinda cool, oil filled greeny color. Any ideas what it may be off, OEM or aftermarket?
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=2ipan60ilkqkeokgakpd85pbt6&/topic,60973.0.html
Re: Mystery Coil
« Reply #1 on: January 26, 2015, 06:44:10 AM »
use transformer oil vhen thange.. ;D..you can get it at all elektro reb firms.(use it on oil cooled transformers)...but cool find..most  vintage car coils have oil inside
i hate all this v-w.... vords
Offline ThomasD883
Re: Mystery Coil
« Reply #2 on: February 06, 2015, 06:48:02 AM »
Little know fact , most automotive C.O.P. ( coil on plug ) setups have oil inside the coil. I believe its there for cooling, and i have heard of coils being burned up by taking a coil that had been sitting at an odd angle and installing and running it too quickly. Overheats and destroys the windings. Never done it myself so take that with a grain of salt.
Diesel deeds, done dirt cheap
Offline strynboen
Re: Mystery Coil
« Reply #3 on: February 06, 2015, 10:33:57 AM »
if you lets the ignision on. (stopped engine).and the platin/knikser is closed...it vill pover the coil up..and make it overheat..it often happents at agrikultur machinery vith gas engines..tractors ect..over night the coil vil get ekstrem hot..and boil the oil aut..think they later build a termo inside..
i have seen cracket coils on cbx 1000..they can get hot ..
Offline ThomasD883
Re: Mystery Coil
« Reply #4 on: February 06, 2015, 03:28:23 PM »
I wonder what the failure was with the VW 1.8 t coils. From what i'd heard the coils were re designed or engineered many times but the problem was never really fixed. I replaced some before 60k miles, between that and the oil sump getting clogged thats how most folks killed those motors. I work with natural gas engines that use heat range 3 plugs, tri fire electrode. Its the most sensitive system ive ever seen, gas fluctuates in quality much more than gasoline. I need to get out of the shop more  :P i bore my girlfriend to tears with this kind of talk. Kudos on your CBX i've seen pictures here, lovely machine, you have my envy.
