Author Topic: Oiling the pin  (Read 1220 times)
Oiling the pin
« on: January 26, 2015, 06:18:06 PM »
What's the consensus about the best way to supply wrist pin lubrication? Holes through the underside of the boss, or horizontal slots machined in the hole? Or both? Apparently there will be milled recesses in the pin hole which help oil the pin surface, but the best way to feed the recess is the question. It seems the choice is mine.
Thanks
Offline johno
Re: Oiling the pin
« Reply #1 on: January 27, 2015, 04:37:08 AM »
Good question Brett,   it seems most auto engineers stick with the options you raised.   ( except Tiny on his salt bike who installed external oil lines to inside the block with oil jets to blast oil everywhere, is that working Tiny ? )
On the old JE pistons I just put in, in addition to the standard oil holes for oil ring back to underside the piston they had a hole drilled from the centre of oil ring to the top of the wrist pin hole  ;)   I thought that was cool  8)
I think as long as you have a hole or groove allowing the whirlwind of oil fumes in the crankcase to work its magic all would be good. ;D
cheers johno
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
Offline Old Scrambler
Re: Oiling the pin
« Reply #2 on: January 27, 2015, 07:32:50 AM »
Yes, Johno, we noted that design on the Old-School J&E pistons.............but also note that the CB1000 rods have squirters on the big-end.  Maybe they could be adapted :) :)  The CB750 oil pump has plenty of capacity ...........I don't know about the unit in Brent's racer ;) ;)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Jim F
  • go baby go
Re: Oiling the pin
« Reply #3 on: January 27, 2015, 07:38:00 AM »
Didn't some of the older GSXRs have oil jets for that purpose?
Sure there is a way
Jim
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Re: Oiling the pin
« Reply #4 on: January 27, 2015, 07:42:11 AM »
Thanks guys. Actually I use a larger capacity pump so piston oiling jets are in the plans but it's not a simple solution on this model unfortunately. The Carrillo's don't squirt either! It's a novel idea to have a drain hole from the oil ring groove, will look at that too.
