Okay now for some correct info. I'll try an address some of the false info given here. PC cures at 375-400*F anyone curing at 500-600 doesn't know what they are doing and are over baking the powder which will fail prematurely. While the cush rubbers won't "melt" at 400* they will cure like the powder and become much harder resulting in premature failure of them up the road. I think the advice you got on the spots is also incorrect. There are a lot of professional blasting businesses out there that don't have a clue to what they are doing. It's just sand being blown out of a hose and it removes paint and #$%*, how hard can it be. Well like any business there are right and wrong ways to do it and those who know there business excel. Those who don't get lots of complaints on the work but manage to stay in business if no one else in the area is doing it. My blaster really knows his #$%* and amazes me at times with what he can do without causing damage or knowing what you as a customer is asking for may cause damage. I've seen all kinds of oil spots in aluminum and the blaster always removes everything down to virgin metal. Out gassing is an issue where in the casting process of the part the pores of the metal close up during the cooling cycle and will trap casting debris and gasses in these pores. When the part has powder on it and starts to flow at temp the pores open in the surface and release all this crap into your melting powder causing bubbles and a restroom and redo. To avoid this the part should be put in the oven at 475-500* for an hour (after cleaning and greasing the part), this allows the pores to open and release all the crud. Then after it cools go straight to sand blasting the part as usual and you will have no outgassing issue or oil spots to content with as this temp will also bring the oil to the surface and burn most of it off. There are also outgassing primers that are sprayed on the part when the part is at full cure temp, this allows the powder to melt/flow/and cure in 1 minute not allowing the bubbliest have a chance to form during a slow cure process. Then the top coat is applied as usual.
Glass bead blasting is not an acceptable means of prepping for PC. It actually peens the surface and leaves an unacceptable surface "tooth" (more gums than teeth, lol) for the powder to adhere to.
If done properly the spokes holes should only be about .00150"-.003" smaller and the spokes should have no issue lacing through them.
