Author Topic: CB750 k7. APE VALVE GUIDES WITH ORIGINAL VALVES¿?  (Read 1168 times)
Offline JBRAVO
« on: February 02, 2015, 02:29:27 PM »
Hello!
I need to replace valve guides. Valves aré in tolerance.
Can i instal o bronce ape valve guides manintaining original VALVES¿?
Do i have to honesto them?
Thanks a lot friends.
Offline Old Scrambler
Re: CB750 k7. APE VALVE GUIDES WITH ORIGINAL VALVES¿?
« Reply #1 on: February 02, 2015, 10:31:33 PM »
Si ;)  But very carefully.............a mild hone :) :) :)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline JBRAVO
« Reply #2 on: February 03, 2015, 05:56:28 AM »
GRacias dennis!
What si a mild hone for You?
Could You explosión?
It's my first time.... And i dont want to damage the envíen
Un saludo from Spain
« Reply #3 on: February 03, 2015, 08:02:32 AM »
The original valve stems MAY have a minor amount of wear making them slightly smaller. The new valve-guides should only be honed to remove any burrs or sharp edges. Each valve should slide smoothly but only drop SLOWLY through the guide under its own weight. You may want to test the fit to get 'matched-sets' before installing. Before 'testing' wipe each valve stem with a clean and lightly oiled cloth.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Offline Big Jay
    • CBRzone
« Reply #4 on: February 05, 2015, 12:48:35 PM »
Yes they work with oem valves.
