Author Topic: frame damage oh no  (Read 14909 times)
Offline Mantree
Re: frame damage oh no
« Reply #25 on: October 21, 2015, 11:12:09 AM »
I am well familiar with him joints having them as the mounts on my sidecar and using them as the conections for my shifter linkage but I feal like that would have more play than this piece from jpcycles.  Trying to fall asleep last night I had a thought and may see if I can get a maching shop to throw a bolt in there lathe and bore a hole for a cable to go threw and then a step up on one end to let the fural sit in the bolt
http://www.jpcycles.com/product/240-988
Sent from my SM-G900V using Tapatalk
Offline Mantree
« Reply #26 on: October 26, 2015, 10:56:18 AM »
I found a break cable from a cm250 with a front drum break is about 4' long and will have some stays made up buy a friend who has access to a machine shop.  Then I just need a cleaves that I can put on the leaver side of the cable
Sent from my ME302KL using Tapatalk
« Reply #27 on: October 26, 2015, 12:07:32 PM »
Mantree,
I am glad that despite the conditions of the inherited frame, you are undertaking a proper repair.
Offline Mantree
« Reply #28 on: October 26, 2015, 12:43:30 PM »
Under took now Tim did a great job on filling it in
Offline Mantree
« Reply #29 on: October 30, 2015, 03:04:02 PM »
So my cable came last night I will be geting the stays made up and geting the new plates for the cb750 engine bolts
The brake light switch will be attached to the pin holding the brake cable to the lever but I still need a clevis made up for the lever side of the cable
Offline lucky
« Reply #30 on: October 31, 2015, 08:22:44 AM »
The stock Honda frame is only 1/16 inch thick, about .062 thousandths of an inch.
If you weld on a tube frame try not to make transverse welds if they are not needed.
To put a patch on a frame that is 1/16 inch thick use a TIG welder.
You want the lowest heat input.
All of the metal needs to be CLEAN.
Do NOT use a grinding wheel on a frame! IT is too severe.
 It will remove too much metal. Just use a scotch write pad. Maybe a little paint stripper .
Offline Mantree
« Reply #31 on: October 31, 2015, 11:47:51 PM »
I had a professional weld it for me I used a during wheel to take off the tab then used a flap wheel to clean the old welds  sand paper to clean anything left then Tim cut a plug and welded it in.  I trust his welds over any other he actually did my sidecar mounts on another bike and  taught me to tig
« Reply #32 on: November 01, 2015, 09:16:52 AM »
What you need on your controls seems to be fairly simple and straightforward.
 But without pics , really hard to help.
Had you posted clear pics in the beginning, we could have helped you thru quickly.
While finding a solution is the main goal, finding an elegant solution, that fits in nicely and compliments the bike.....is even better..
Offline Mantree
« Reply #33 on: November 01, 2015, 02:08:52 PM »
Well I have templates for the bracket for the forward controlls mounts I'll get a copy of the template up soon and I have a dissing for a clevis that I will be making out of aluminum stock that will let me just slide the end of the cable in so if the cable needs replaced at any point it's simple to just pick up a replacment cable from anyone that sells honda cables.  I have a guy making me a sissybar and he said he will machine me some cable stays using round stock welded to some plate like  this
Then I am going to order some cable clamps off j&p to hold the cable to the frame
« Reply #34 on: November 01, 2015, 06:36:29 PM »
Machined ? Looks like he just cut a piece of pretty thin tubing and welded it on..
It should fit nicely to the part that is inside it, and have a slot to get the cable in and out....
Offline Mantree
« Reply #35 on: November 01, 2015, 07:06:57 PM »
That is just one I found online.  The guy I have doing this has a lathe to make it right and heavy duty
Offline Mantree
« Reply #36 on: November 02, 2015, 08:51:13 AM »
So I will be shortening the cable as it is about 6" to long
Offline Mantree
« Reply #37 on: November 08, 2015, 11:04:21 PM »
I have found a routing that will let me use the whole length so I don't have to cut he cable and I have designed a mount that uses the stock mount and will be making it out if aluminum stock when I have time
Offline Mantree
« Reply #38 on: April 14, 2016, 11:37:30 AM »
So sissy bar on new regulator rectifire unit on the way, new barrier blocks coming to clean up the flying spaghetti monster in the headlight bucket and a starter solinoid so that I can get my electric start back.  Still no progress on the forward controlls yet
Offline Mantree
« Reply #39 on: April 14, 2016, 02:57:34 PM »
Summer is soon so I need to get ready for some camping
Offline mystic_1
  • 1970 CB750K
« Reply #40 on: April 14, 2016, 03:33:29 PM »
Nice.
I always like to see bikes with Konged frames, they make me feel so much better about the comparatively much milder mods I made to mine :)
Also, tell me more about those bars please.
mystic_1
- John Augustus Shedd
Offline Mantree
« Reply #41 on: April 14, 2016, 09:35:32 PM »
Nice.
mystic_1
The bike was chopped up by my uncle in the late 70s.  The handlebars are called window handlebars they are a set of stock bars with what are esentaly welded on risers I'll try to grab some pictures when I get home tomorrow morning.
Offline Mantree
« Reply #42 on: April 15, 2016, 08:44:00 AM »
Nice.
mystic_1
You could get the same effect with these
http://m.ebay.com/itm/361197042475
« Last Edit: April 15, 2016, 08:49:15 AM by Mantree »
Offline mystic_1
  • 1970 CB750K
« Reply #43 on: April 17, 2016, 05:20:58 PM »
Oooh, I get it now, my eyes were playing tricks on me with regards to how they were mounted.
It's very cool that you know the history of the bike and you're keeping it on the road after all these years.
mystic_1
Offline Mantree
« Reply #44 on: April 18, 2016, 09:17:23 AM »
mystic_1
My uncle owned it from the factory and it has rolled the odometer 3 times according to him before he passed away last year from a heart attack
Offline Mantree
« Reply #45 on: April 19, 2016, 05:26:09 PM »
Got my new regulator rectifier and installed a new plug wired on.  It will be mounted under the battery box.
Offline mystic_1
  • 1970 CB750K
« Reply #46 on: April 19, 2016, 05:35:28 PM »
Nice and clean looking.  Well done.
Although, I personally have developed a deep dislike of that style of split loom and instead switched over to the braided expandable stuff.  You'd need to put it on before the connector, though, or else pull the pins out of it to feed the wire through.
mystic_1
Offline Mantree
« Reply #47 on: April 19, 2016, 07:05:04 PM »
mystic_1
Thank you. I only used this because I have a mountain of it from my old job.  I wanted to use these
Kaifa 1 Sets Kit Deutsch Dt 8 Pin Waterproof Electrical Wire Connector Plug Kit 22-16Awg Dt04-8P Dt06-8S Kf00027 https://www.amazon.com/dp/B017RO506A/ref=cm_sw_r_other_awd_DsUfxbH0BHKGV
But they are rather expensive
« Last Edit: April 19, 2016, 07:11:06 PM by Mantree »
Offline Mantree
« Reply #48 on: April 20, 2016, 04:09:48 AM »
I drew up a new wireing diagram including the terminal blocks I will be using to cleen up the headlight bucket
Offline Mantree
« Reply #49 on: April 21, 2016, 10:10:29 AM »
New regulator rectifire in just need to put a plug bike side to plug it in
It's mounted under the battery tray that is part of the oil tank
