Author Topic: First post - 77 cb750 behind a barn find  (Read 2481 times)
Offline Mark Wilson
« on: February 06, 2015, 09:18:10 AM »
While not all that seriously considering a bike or a project, I was scanning Craigslist last week and stumbled on a neglected 77. I just couldn't help myself, so did the deal, gave the man $550 and he signed the title. It's been sitting behind a barn with a tarp for a couple years and hasn't run in several more. Motor turns but rear wheel not so much. Loading and unloading was an exciting experience!
First order was to rip off the fairing. Whoever installed it used some kind of medieval weapon to butcher up the headlight bucket - Nice! I then pulled the carbs to see what lurked and was very surprised they were clean. Drained what little oil was still in the case and found it pretty goldish and clean. This weekend, I'll soak the carbs, get the back wheel turning and figure out how to jumper the ignition switch(no key). Next week if all goes well, I'll hang a temp fuel bottle and see if the old girl still has any life in her. High fun factor!
Offline Maurice
Re: First post - 77 cb750 behind a barn find
« Reply #1 on: February 06, 2015, 09:58:46 AM »
Wow nice find.
Rear wheel probably just has the brake stuck close. Just lightly hit the actuator on the plate, towards the back.
Good luck
Offline calj737
  • I refuse...
« Reply #2 on: February 06, 2015, 10:08:44 AM »
And you can jump the solenoid with power to bypass the key. Might be good to drizzle some oil in the top end, remove the plugs and drip some Marvel Mystery Oil down the chambers, and rotate the crank to lubricate the motor before "firing it up" since its been sitting,
Offline Mark Wilson
« Reply #3 on: February 06, 2015, 11:31:38 AM »
Great suggestions - Thanks!
Offline rb550four
« Reply #4 on: February 06, 2015, 02:13:21 PM »
Nice find!
  It's always better to buy a  new battery, never jump off a running car. And instead of guessing how to hotwire it, you'd be better off with a new switch even a cheap one is cheaper than messing the wiring up.You'll need one anyways. And always, always have a shop manual.
Offline Mark Wilson
« Reply #5 on: February 06, 2015, 05:52:00 PM »
Spark plugs showing OK and a little life after all the years of neglect.''
Offline FridgeRaider
« Reply #6 on: February 06, 2015, 08:20:35 PM »
I saw that listing on CL a couple weeks back and thought to myself "someone better buy that before I have another project on my hands". Congratulations on that sweet deal! What conditions are the pipes in?
1972 CB750K2 Resto-mod (836cc Upgrade) - http://forums.sohc4.net/index.php/topic,161782.0.html
Offline Mark Wilson
« Reply #7 on: February 07, 2015, 03:16:14 PM »
Carbs soaking in Pine-sol
Back wheel off to get brake loose
After a little clean up
Offline Mark Wilson
« Reply #8 on: February 07, 2015, 03:17:38 PM »
Pipes are toast - chopped them off today.
Offline Mark Wilson
« Reply #9 on: February 10, 2015, 06:58:59 AM »
Carbs cleaned and back on. Oil changed. Trying to figure out throttle linkage now. Why didn't I take pictures???? :o
Offline Trad
« Reply #10 on: February 10, 2015, 10:49:37 AM »
Nice work. Glad you're bring this one back to life.
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
Offline Johnie
« Reply #11 on: February 10, 2015, 10:57:23 AM »
Nice find. Amazing it sat outside that long and she is not froze up. Nice to see you are keeping it original. Here is a pic of my new K7 when I brought it home from the dealer in 1977.
« Last Edit: February 10, 2015, 11:00:00 AM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Mark Wilson
« Reply #12 on: February 10, 2015, 05:08:01 PM »
Carbs reinstalled. Took two nights fiddling with the throttle linkage to get it back in place. The gas tank is filled with apple cider vinegar to kill the rust. Test start this weekend!
Offline Mark Wilson
« Reply #13 on: February 19, 2015, 05:55:21 PM »
Success! After chasing several electrical faults she came back to life today - if only for a short time. This was on starting juice. She hasn't remembered how to pick up fuel from the bowls yet. I call it a win.
<iframe width="420" height="315" src=" frameborder="0" allowfullscreen></iframe>
Offline kap384@telus.net
« Reply #14 on: February 19, 2015, 06:45:20 PM »
<iframe width="420" height="315" src="https://www.youtube.com/embed/apCyihNo1vk" frameborder="0" allowfullscreen></iframe>
Great news
1965 Honda CB450K0
1972 Honda CT70K1
1975 Honda MR50
1975 Honda CB400F Supersport
1977 Honda CB750F2 Supersport
1978 Honda XL100
1979 Honda CBX Supersport
1982 Honda VF750S Sabre - Adventure Bike modified
1983 Honda CX650T
1995 Honda VFR750
2016 Honda CRF1000L Africa Twin
2015 KTM 200 XC-W
1963 Suzuki T10
My 1977 CB750F restoration - http://forums.sohc4.net/index.php?topic=66779.0
My 1975 CB400F restoration -
http://forums.sohc4.net/index.php?topic=145196.msg1651779#msg1651779
'More Stock Than Not' thread - http://forums.sohc4.net/index.php?topic=90807.500
My CT70 Resurrection - http://forums.sohc4.net/index.php?topic=145221.0
Best Motorcycle Tool Ever - https://www.engduro.com
Offline Mark Wilson
« Reply #15 on: March 04, 2015, 06:24:35 AM »
After a little more tinkering, the old girl came to life. I'm actually pretty surprised that she starts as quickly with the old plugs and points.
