Author Topic: Neutral switch?  (Read 961 times)
Offline stewonepot
Neutral switch?
« on: February 10, 2015, 11:58:07 AM »
Hi All
Is it possable to rebuild a neutral switch on a CB750f1 ?
Or as i think i need a new one.
The light stays on when in gear
Regards Stew
Re: Neutral switch?
« Reply #1 on: February 10, 2015, 12:08:03 PM »
Would not hurt to take it out and clean it.   It can be just stuck or the wire has broken insulation and grounds itself.
Re: Neutral switch?
« Reply #2 on: February 10, 2015, 12:36:29 PM »
+1
its an easy clean.
might even just be corrosion/roadgrime at the connection and not needing to come out.
Left side of the engine, underneath.  you'll see a wire attached by a small JIS screw on the lower case.
remove the screw, clean the wire connector, and the location it screws into.
might just do it.
Re: Neutral switch?
« Reply #3 on: February 10, 2015, 07:08:04 PM »
Hi All
Regards Stew
Disconnect the wire from the switch; if the light stays on, the problem is not with the switch.
Offline mcswny
Re: Neutral switch?
« Reply #4 on: February 11, 2015, 07:59:41 AM »
Have you messed with any of the wiring inside your headlight bucket?
1972 CB750 K2
1997 XR600r (street legal)
1975 XL250
198 XR80
Re: Neutral switch?
« Reply #5 on: February 11, 2015, 08:06:38 AM »
Neutral switch:
Where to find it:
Offline Whaleman
Re: Neutral switch?
« Reply #6 on: February 11, 2015, 10:04:48 AM »
Not rebuildable only cleanable. Sealed unit. Dan
Offline stewonepot
Re: Neutral switch?
« Reply #7 on: February 11, 2015, 10:15:24 AM »
Hi all
I think the wiring is ok as the light goes out in first gear ,but stays on through  N 2 3 4 5
I saw in the good photos that there is an o ring for the switch. My one is leaking a little bit maybe good to replace.
Re: Neutral switch?
« Reply #8 on: February 11, 2015, 10:37:28 AM »
pull the unit.  clean it, and hook the wire too it.  key on.
ground it against the engine.  N light should be on
depress the ball, light should go off.
Offline krusty
Re: Neutral switch?
« Reply #9 on: February 11, 2015, 11:43:05 AM »
And replace the O ring.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
