Author Topic: CB750A - EFI project  (Read 9503 times)
Re: CB750A - EFI project
« Reply #25 on: November 11, 2018, 04:27:08 PM »
Yes. More air = more fuel = more HP.
Offline ratranger
« Reply #26 on: November 24, 2018, 08:36:48 AM »
If you haven't settled on a fuel pump set up, you can do an intank one pretty small if needed.  I used a ninja650 regulator and a sportster 1200 pump with a home made sending unit.  It required a 1.55"×2.1" hole to be cut in the tank.  Holds steady at 41-43psi all the way to redline on my XS, no leaks, internally regulated, fits a tiny tank.  Just throwing it out there to show the possibilities.
