Author Topic: Injection  (Read 5119 times)
Rocking-M
Injection
« on: October 10, 2006, 05:32:08 PM »
Anyone out there converted to fuel injection?
It would seem that the carbs could be gutted and injectors installed.
Any thoughts?
Offline Pinhead
  • 1979 CB652-ST
Re: Injection
« Reply #1 on: October 10, 2006, 05:40:59 PM »
I was thinking the same thing, was going to try to install and program a MegaSquirt, but being a poor college student doesn't lends itself to spending that much dough on my bike...
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
Rocking-M
Re: Injection
« Reply #2 on: October 10, 2006, 05:43:00 PM »
I was gonna mention mega squirt. I'm planning to mega squirt the fiat this winter (if budget allows:))
So that may be an option for the honda too! Interesting.
Offline Geeto67
  • A grumpy
Re: Injection
« Reply #3 on: October 10, 2006, 06:20:07 PM »
Posa carbs were a crude mechanical injection back in the 70's (hard to call it true injection - about halfway between a carb and injection).
To be honest the stock carbs are so reliable and easy to tune that fuel injection dosen't make much sense - espically with the added fabrication of adding a fuel pump and return feeds. It is unlikely that there will be any benefit to FI a stock motor other than to show off that you did it and it is possible. Now if you were going to add a power adder like nitrous or a turbo then FI starts to make sense since traditionally these are areas where the stock carbs prove inadiquate.
There are two ways I have thought about doing it and here they are:
1) I would use a (Wayne and Son) Log manifold with an adapter for a honda car throttle body. The manifold would have small car injectors at each intake port. Using a mega squirt controller to power the whole thing and an O2 sensor in the exhaust. Fuel pump would be a small aftermarket electric one for honda cars. The system would be Throttle position sensor not mass air so programming a map would take some time. With this setup I could see plumbing a turbo and nitrous fairly easily into the system. I envisoned the engine would be an 836 kit wilt 8 1/2 compression (they used to make those kits - are they still around?) and a short duration cam.
2) would be to adapt a cbr throttle body setup to the bike. Haven't really played with this idea too much but modern bikes are FI. some of the earlier FI cbrs are TPS and cable actuated (unlike the R1 which has the TPS sensor in the throttle grip itself - necessitating the use of the R1 computer).
Maintenance Matters Most
Re: Injection
« Reply #4 on: October 10, 2006, 06:33:14 PM »
The 3/4 midget racer guys have been using fuel injection on the 750 engine for quite some time. There is a bolt on system still available. Hilborn I believe. Many of these guys are switching from the 750 engine to more modern power plants as there rules allow. This group is a good source for NOS and used parts.
Offline Geeto67
  • A grumpy
Re: Injection
« Reply #5 on: October 10, 2006, 06:53:52 PM »
some drag racers use the hilborn and kinsler systems also, the old systems are mechanical injection and not really suitable for street and part throttle applications. However there are plenty of companies that do EFI hilborn conversions for cars (including hilborn themselves) and it would pe possible to convert the mechanical setup to EFI. The modern EFI is hella expensive ($3000 starting)
Offline Pinhead
  • 1979 CB652-ST
Re: Injection
« Reply #6 on: October 10, 2006, 08:22:19 PM »
I'd rather use a "DIY" system like the MegaSquirt. I'd think you could build the system for a lot less than $3000...
Doug
:D
Offline Nate
    • Alternative Cruisers BB
Re: Injection
« Reply #7 on: October 10, 2006, 08:28:05 PM »
The MegaSquirt option does seem like a less expensive option, but damn that's some heavy stuff. Definately for someone with time and money on their hands, in other words not me  ;D
VitaminCB550
Re: Injection
« Reply #8 on: October 11, 2006, 08:52:35 AM »
I would think that there would be a significant increase in electrical draw... Wouldn't this be an issue?  ??? ???
Re: Injection
« Reply #9 on: October 11, 2006, 09:13:11 AM »
Yes IMO
Offline Pinhead
  • 1979 CB652-ST
Re: Injection
« Reply #10 on: October 11, 2006, 10:18:53 AM »
It would definately increase electrical draw on an already mediocre charging sytsem. However, if someone were to put the time into their bike it would take to add fuel injection, tune it, and make it run right, they would probably also replace the stock alternator components with higher output aftermarket ones.
Doug
:D
Offline Pinhead
  • 1979 CB652-ST
Re: Injection
« Reply #11 on: November 09, 2006, 11:19:44 PM »
So is there anybody that's worked with Megasquirt, etc.?
Doug
:D
Offline Geeto67
  • A grumpy
Re: Injection
« Reply #12 on: November 10, 2006, 06:20:21 AM »
I found this link kinda interesting, It is fuel injection conversion to a two stroke RZ350:
http://www.smcomp.com/~smurph/RZ-EFI/index.html
It is really a nice look at the work involved in a conversion.
As far as the charging system, go find an old magneto setup to run the motor and just keep the stock alternator to charge the battery, frees up a lot of current if the battery isn't firing the cylinders anymore.
cafetero1
Re: Injection
« Reply #13 on: November 10, 2006, 07:38:39 AM »
Lots of useful information here:
http://cb1100f.net/modules.php?name=Forums&file=viewtopic&t=13119&highlight=megasquirt
About halfway down on page 8 of the thread, there is a video link.  It shows the absolutely nasty throtle response this product will get you.  While in the video link, take a look at his 'stompin the 900 fulie'.  Insane.  Gotta love it though.
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
Re: Injection
« Reply #14 on: November 10, 2006, 08:07:30 AM »
It would definitely increase electrical draw on an already mediocre charging system. However, if someone were to put the time into their bike it would take to add fuel injection, tune it, and make it run right, they would probably also replace the stock alternator components with higher output aftermarket ones.
            And where is it that you're going to get these "Higher Output Aftermarket Alternator Components? Seems  to me that I've seen several posts on Wanting a better charging system for the 550s and, to my recollection, nobody has any answers. I believe that the "Better Charging System" with or without going to fuel injection. I mean, if improving the lighting on the bike taxes the charging system, then that should be the area that needs tending to first. Just my opinion, and some others. If you're seriously thinking about fuel injection, you should also do some improving on the motor itself (intake, cam and exhaust). Won't do much good to shove the fuel mixture in, if it can be taken care of efficiently and gotten rid of effectively, you know? I have to go with Geeto & MRjeck's comments.
                                                        Later on, Bill
Member # 1969
Offline dusterdude
Re: Injection
« Reply #15 on: November 10, 2006, 08:42:56 AM »
injected?,i`d rather be blown.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline bill440cars
Re: Injection
« Reply #16 on: November 10, 2006, 12:52:13 PM »
             I'm not touching that one. :-X
Member # 1969
Offline dusterdude
Re: Injection
« Reply #17 on: November 10, 2006, 01:48:32 PM »
thank you
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline Hockers Choppers
  • go away winter!!!
Re: Injection
« Reply #18 on: November 10, 2006, 02:15:13 PM »
I was waiting for a comment about building up a mega squirt!! :o
The thing about common sense is that, it's not that common.
1978 CB750F SUPERSPORT 850cc, cam, porting, dyna ign, cr29's lotsa elbow grease and $$'s. Worth ever penny!!  (S0ld)
05 VTX1800F darkside
cb750 k1
  • go away winter!!!
Re: Injection
« Reply #19 on: November 10, 2006, 02:19:58 PM »
I just got rid of my 2003 ultra glide with efi. I had a 2-1 header, cams and the harley race tuner for the efi in the bike. It was a nightmare, I never did get that pos to run right. I was happy to get back to carbs, even though 4 carbs are a real pita to tune also. But at least I don't have to take it to a shop that charges $55 an hour to work on it. If I could leave something stock it would solve alot of my problems, but that would be way to easy.
cb750 k1
Offline Pinhead
  • 1979 CB652-ST
Re: Injection
« Reply #20 on: November 10, 2006, 03:42:19 PM »
 Later on, Bill
I've seen aftermarket charging systems for the 650/750 models, but haven't really looked for parts for the 550. It's all about how much you want to spend on the parts. You can buy a $220 stator and $400 rotor from online retailers that claim 400 clean watts out, which is about 30 amps. Plenty to run these bikes with a computer controller.
I also agree that you would want to build the engine to take advantage of the injection system. I plan on (within the next 10 years :) ) building a SOHC4 utilizing fast burn technology and computer controll components. I've already emailed Larry Windmer (www.theoldone.com)... He builds engines that make 1hp/cc. I won't be getting that much out of an old SOHC (being air-cooled, and would blow head gaskets and heads) but 1/4 hp/cc should be possible.
The injection would be required to make the full throttle range usefull throughout the entire RPM band. Megasquirt's can be programed for highway cruising mileage, as well as WOT (18:1 A/F ratio at cruise, 14.7:1 under moderate acceleration, and 12:1 at WOT). I'd use a MAF sensor, MAP sensor, knock sensor, and wideband O2 sensor.
Here's a video with a DOHC CB900 FI'd. Watch the throttle response.
There's a difference, though. If you put a Megasquirt together you don't have to pay someone to work on it. You hook the thing up to your laptop and tune it yourself. The "stock" injection isn't really tuned to be the most efficient, anyway. You can easily get more power and more mileage if you tune it yourself with disregard to emissions, etc.
This guy used 2003 gsxr600 injection bodies on his 900F and a megasquirt. The subject is pretty interesting. Seems worth it.
http://cb1100f.net/modules.php?name=Forums&file=viewtopic&t=13119&postdays=0&postorder=asc&highlight=megasquirt&start=0
Doug
:D
  • go away winter!!!
Re: Injection
« Reply #21 on: November 10, 2006, 05:39:09 PM »
Hey Doug, When are going to stop in Victoria ? My bike is in a million pieces and I need someone to put it back together ;D. The race tuner I had could be hooked up to a laptop, but your just guessing at it unless you have it on a dyno with an exhaust gas analizer. Seat of the pants tuning will only get you close and takes a lot of time. I was getting 82 hp and 90 ft lbs of torqe out of an 88 ci engine. Pretty good for a Harley. Was only getting 30 mpg  >:(.  Thats the main reason I sold it and found a sohc to play with. I can't wait to get it back together with the big bore, cam, ported head, cr carbs, etc. I'll dyno it when I get it done. Stock it had 54 hp and 35 lbs. any guess's with the new stuff? Has anyone else dyno'ed a big bore cam setup?
cb750 k1
Offline bill440cars
Re: Injection
« Reply #22 on: November 10, 2006, 06:44:20 PM »
          Doug,  Gotta hand it to you. I didn't know about the aftermarket charging systems and what you said the price range was tells me I don't want to know about them. :o Too expensive for me.  ::)
                                                             Later on,  Bill :) ;)
Member # 1969
Offline old750
  • Hippy ass bike.
Re: Injection
« Reply #23 on: November 10, 2006, 08:08:13 PM »
Hey Pinhead, I've been looking for a better charging system on my 750k2. I had a post a few weeks ago inquiring about possible better charging systems but no luck. Who sells a 400 Watt charging system???
Offline Pinhead
  • 1979 CB652-ST
Re: Injection
« Reply #24 on: November 10, 2006, 09:18:36 PM »
Let me see if I can find that link again...
Doug
:D
Offline old750
  • Hippy ass bike.
Re: Injection
« Reply #25 on: November 10, 2006, 09:36:38 PM »
I would appreciate it. I want to completely cover my bike with neon lights ;D just kidding.
