Author Topic: 750 countershaft gear orientation  (Read 445 times)
DH
« on: March 02, 2015, 07:25:44 AM »
http://www.westernhonda.com/fiche_section_detail.asp?section=2560049&category=Motorcycles&make=Honda&year=1975&fveh=132839
Part #14. Mine slid off the countershaft by accident while handling. I THINK it's installed correctly but, not sure.
I know the gear will inststall/fit on the shaft either way round, but is there a way to tell which is correct? Any identifying
marks or offset differences in the hub area? Am I missing something? Don't want overthink the issue, but don't want to have to split the cases again either. Any information is much welcome.
Offline mystic_1
  • 1970 CB750K
Re: 750 countershaft gear orientation
« Reply #1 on: March 02, 2015, 10:10:37 AM »
I just commented about this in a different thread:
http://forums.sohc4.net/index.php?topic=138663.msg1656033#msg1656033
tl;dr: one side of the gear has a taller flange near the "hub".  That side should point away from the other gears.  See link for pics.
mystic_1
- John Augustus Shedd
DH
« Reply #2 on: March 02, 2015, 11:54:12 AM »
mystic_1
mystic, I'm thinking that the gear in your link is the one next to the one I am concerned with. Mine is on the very end of the shaft, just before the countershaft goes into the countershaft roller bearing that is mounted in the case. Your thoughts?
Offline mystic_1
  • 1970 CB750K
« Reply #3 on: March 02, 2015, 01:09:15 PM »
Ah you're right, you mean the final drive gear.  If I recall correctly, that gear is symmetrical, so there's not so much a right way and a wrong way to install it.
You may be able to get some clues as to it's original orientation by looking for wear patterns on the gear surfaces, but I don't believe it's orientation matters.
mystic_1
« Reply #4 on: March 02, 2015, 01:23:48 PM »
mystic_1
+1
Just had these in my hands yesterday.
#14 from your picture (final drive gear) can be installed either way.  Its #4 next to it, that has a specific orientation.
DH
« Reply #5 on: March 02, 2015, 01:40:47 PM »
Thanks guys. Hopefully I'll get it back the right way it was, and if not, it won't be noisey from running it the other way round.
Offline martin_uk
  • CB750F1 CB750K8
« Reply #6 on: March 02, 2015, 02:03:19 PM »
On my K8 there was a difference, which can be seen if you put a straight edge across and one side inner flange was level and other recessed.
If you look at sectional drawing in manual you can see the difference.
CB750F1, CB750K8,  Triumph Street Triple R, AJS 350, Triumph 3TA
DH
« Reply #7 on: March 02, 2015, 04:10:46 PM »
I did that with the straight edge, but couldn't see any difference on mine (k5). Maybe the k8 is different?
