Author Topic: Clean oil lines?  (Read 4512 times)
Offline dgilling
Clean oil lines?
« on: February 14, 2015, 11:20:38 PM »
What's the best way to clean up the oil lines? Is it even worth it. Mine where all black, then I power washed them now they're a faded white with some black. Can you paint the nylon?
Re: Clean oil lines?
« Reply #1 on: February 15, 2015, 01:40:42 AM »
Your best bet is to figure out a replacement, every so often somebody reports a leak from the hose. The oil is under zero pressure in there but old hose will eventually leak.
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #2 on: February 15, 2015, 01:41:17 AM »
I used some of that plastic spiral armour sleeve stuff to tidy mine up, the kind used for bundling wiring together. No need to take off the hoses :)
Build threads:
1977 CB750 F2
1958 Norton Model 99
« Reply #3 on: February 15, 2015, 04:57:13 AM »
Black shoe polish!
« Reply #4 on: February 16, 2015, 07:37:50 AM »
I pressure washed them too.  they came out light gray.
First i tried full strength RID fabric dye to darken them.  It worked, but not well enough.
Once dried, I taped off the ends and used VHT flat black header paint.
Still look great after a year  ;D
Offline dgilling
« Reply #5 on: February 16, 2015, 08:06:22 AM »
Thanks Flybox, I have some VHT header paint Left over.  I'll paint them tonight.
« Reply #6 on: February 16, 2015, 10:12:00 AM »
No risk that the rubber in the oil lines start to crack due to age?
Offline Airborne 82nd
« Reply #7 on: February 16, 2015, 10:34:28 AM »
I too would be more concerned about the inside. I vote clean up the ends and replace the old rubber. I went with the stainless mesh cover.
« Reply #8 on: February 16, 2015, 03:24:51 PM »
My point above, 40 years old rubber is nothing I would call reliable.
Offline edwardmorris
  • Youngish
« Reply #9 on: February 16, 2015, 03:32:12 PM »
Prokop, didn't you DIY braided stainless replacements? If you could please post up details, I'd like to save the leaky pair on my K3.....
« Reply #10 on: February 16, 2015, 03:45:30 PM »
Yes, I did. McMasterCarr has SS ferrules, your local hydraulic shop will match your fitting to a hose and all it heeds is a crimp.
Some members, like Kickstart, had luck just taking a hose to hydraulic shop and getting them crimped, I was never able to do that.  Napa would not take a chance, Coliflower did not have the right size crimp, it was frustrating.
For my project I found finally this jig at Home Depot, it is used to crimp the new style of house water lines and I paid $25 or so for it and it crimped the hose well enough.
Here it is on Amazon, but I found it locally.
http://www.amazon.com/Superior-Tool-07100-Pocket-Crimper/dp/B002RBAADC
« Last Edit: February 16, 2015, 03:48:32 PM by 70CB750 »
  • Youngish
« Reply #11 on: February 16, 2015, 03:52:08 PM »
Thanks! I'm having terrible luck at the local hose shops too. Somehow they knew they aren't standard hoses and pulled it outta me that they were for a motorcycle. Once they heard that, there was no talking to them. One more q, what size ferrules to go with? I'm sure I can figure out hose diameters, unless you know them off the top of your head....
Offline oldhatt45
« Reply #12 on: February 16, 2015, 05:53:27 PM »
Ed,
Try this place.  http://www.indrubber.com/index.html
It is Industrial Rubber in Elizabeth, NJ.
They have done SCUBA Hoses (5000 psi), Gas Mixing whips (also 5000 psi), and High Pressure lines for the Detroit Diesels I had on my boat.
Admittedly this spans the last 20+ years, but possibly if you call them and ask, you'd only be out  the price of a phone call at worst.
Hope this helps
Charlie
« Reply #13 on: February 17, 2015, 03:53:35 AM »
Yes, they would not take the responsibility or they did not have the spirit that makes things happen, suckers :)
I am pretty sure, these were the ferrules:  9256T35
Just put that code in the search on McMasterCarr web and it will come up.
http://www.mcmaster.com
  • Youngish
« Reply #14 on: February 17, 2015, 10:51:30 AM »
Thank you! I'll give it a shot and post in my K3 build thread. I found a thread that had the correct hose dimensions listed, but now I can't find it again  >:( >:( Will post here when I do.
Offline dgilling
« Reply #15 on: February 18, 2015, 10:26:59 AM »
So why not just buy new stainless ones from CB750 cafe for $69?
http://www.cb750cafe.com/products-page/cafe-parts/stainless-braided-oil-lines/
  • Youngish
« Reply #16 on: February 18, 2015, 02:20:34 PM »
Found the thread http://forums.sohc4.net/index.php?topic=15821.0
The DIY price is half of CB750 cafe price. I'm going to try this.
-10AN 3' stainless hose from Jegs : $20
9256T35 ferrules from McMaster: $5.51
say roughly $30 shipped for everything. Any local auto shop that provides A/C services will have a hose crimper or you can invest in one like Prokop posted above.
« Reply #17 on: February 18, 2015, 04:03:45 PM »
First time I see them this cheap.  Somebody here posted SS oil hoses he was making for $150 - 2 years ago or so.
« Reply #18 on: February 18, 2015, 09:06:27 PM »
How do you remove the old end fitting from the old hoses so the new stainless can be crimped on?
« Reply #19 on: February 19, 2015, 03:26:53 AM »
I use hacksaw and cut off the side of the ferrule, parallel to the hose.  Or you can do what he did:
Offline 72 yellow
« Reply #20 on: February 19, 2015, 06:17:27 AM »
Looking at Carpy's oil lines, the ends are not crimped.  They are held on by stainless hose clamps with covers.
Offline dgilling
« Reply #21 on: February 19, 2015, 09:33:12 AM »
I feel like I have so much more to do that an extra $30 is worth it to just buy from cb750 cafe
« Reply #22 on: February 19, 2015, 01:11:16 PM »
ok, so the ferule is not part of the hose end fitting?  I make a lot of hydraulic hoses at work and the part that gets crimped/ferule is an integral part of the hose end.   They can only be crimped once.
« Reply #23 on: February 19, 2015, 03:12:58 PM »
Thats correct, the ferrule slips on the hose for the crimp.
These are not hydraulic hoses, only oil supply. They carry 0 psi pressure.
  • Youngish
« Reply #24 on: February 19, 2015, 03:18:16 PM »
Stuff's on its way, hopefully some pix soon when I get it together next week. Thanks Prokop and Mikeb4.
