Author Topic: High altitude 73 CB500 daily driver ( 5/20/17 update )  (Read 35741 times)
Offline Desert Dan
  • Some might call me an
Re: High altitude 73 CB500 daily driver (Timing issue fixed)
« Reply #75 on: May 16, 2015, 01:27:55 AM »
  So not much in the way of progress to report right now, Ive been riding the 500 every chance I can get which is a bit sporadic considering the daily rain showers Colorado has been getting these last couple of weeks. I reached the 500 mile ring break in point so Im now able to give the bike the beans and see what it can do, which is not as much as I was hoping. It appears I have more tuning to do to ring out every last drop of performance I can. I attempted to do the ton on a long straight section of highway but the bike reaches it's limit at 90mph which is faster than Ill need it to go but I'd like to hit 100mph once just to put the notch in my belt. Im going to order some smaller idle jets because the plugs and cylinders get pretty wet and carbon fouled at this altitude when I idle for any length of time, and I have a theory that even at speed a little fuel goes through the slow jets contributing to the richness of the mixture because the mains are now much smaller than stock.
  Ive also been on the look out for a new exhaust as the current 4into2 sounds just a little too choperish and doesn't make that smooth four cylinder sound that I want. Ideally I'de like to find a stock 4into4 and I was a day late on the one RiverFever had for sale, but the cost of a stock exhaust is somewhat prohibitive so Ive been knocking around the idea of getting a 4into1. Im hesitant to get one as most of the 4int1's I see for sale require them to be removed to change the oil filter which isn't the end of the world, but what Im most worried about is that it might contact the stock fender when braking or going over bumps. I like the look and the price of the lossa engineering exhaust as the stainless steal one comes in at $500, but I'd like to see what other people have to say about it.
   I also did another tune up today (valve lash and carb sync) and discovered a few problems. Firstly I installed Honda 5.5mm fuel line (which is excellent much better than 1/4in or clear plastic fuel line) while at the same time eliminating the in line fuel filters I had been using. The inline filters were causing just enough of a restriction to keep my carb bowls from over filling with the stock 22mm float height and the stronger sprung aftermarket needle valves. Now without the restriction of the filters my carbs piss fuel out of the drain tubes while at idle, so I need to pull the rack of carbs and find a float height that will keep the carbs happy. Secondly sometimes at idle I would here a momentary popping noise that I thought was just excess pressure coming out the vent tube, it turned out to be my #1 spark plug wire shorting to ground occasionally while idling. I attempted a shade tree fix with electrical tape and bicycle inner tube but that only worsened the problem. It's an easy enough fix and more than likely caused by the brass pin I used to replace the old wires with being pushed through the plug wire shielding, Ill just have to redo that plug wire when I get around to setting the float heights.
  Besides those momentary hick ups the 500 is running beautifully and the top end is bone dry and doesn't leak a drop of oil.
Offline riverfever
« Reply #76 on: May 16, 2015, 08:04:22 AM »
Thanks for posting more pics of that filter setup Dan. I'll be trying that as well. Sorry we couldn't hook up on the exhaust. Would have been perfect for both of us. I rarely see anyone else wanting to run the stock fender with a 4 to 1 and the few pictures i have seen look just as tight as mine and I find it very hard to believe there's no contact unless there's just no travel in the forks. My new tires will be here later this week and once I get them mounted I'll start looking at tastefully modifying the fender so I can run it and still have things be safe. I think it looks good and, as you said, we get those daily showers here so it would be nice to have the coverage. I'll let you know how things work out.
Offline Desert Dan
« Reply #77 on: May 16, 2015, 08:34:13 PM »
I took some quick shots of the clearance between my stock fender and my current headers if you want to compare and contrast with your 4into1. I have no idea if they're cut down stock headers or not but they clear the oil filter housing and they don't hit the fender. I imagine since many 4into1's cover the oil filter housing they must stick out a good deal further narrowing the gap with the fender.
Online HondaMan
« Reply #78 on: May 16, 2015, 10:17:08 PM »
One of the things that is real important for that hi-RPM work is: perfect spark. If you can, consider getting at least a set of the coils from PartsNmore instead of trying to reach 100 MPH with 'repaired' coils and arcing wires.
Then maybe consider a Transistor Ignition, too: it will improve the spark everywhere. That's why I started making them again.
Offline Desert Dan
« Reply #79 on: May 17, 2015, 12:29:15 AM »
   I have been reading all sorts of articles of transistor ignitions I even downloaded a wiring diagram, parts list, and instructions to build a single points unit to try out on one of my Volkswagens. Your transistorized ignition has been on my wish list for some time now and as soon as my budget allows I plan on ordering one from you, from what Ive read on transistorized ignitions and from reviews of your ignition from other SOHC4 members there are no downside to using one which makes it all the more appealing.
   As of right now Im fairly confident I can repair the arcing #1 wire as the other 3 wires I installed in the coils are working fine and aren't arcing. When I first tested the coils I made a spark tester with a 7mm gap and all 4 wires were capable of jumping the gap with a hot blue spark. If I can't satisfactorily replace the #1 wire Ill bite the bullet and buy a set of new coils. The attempt to reach 100mph was done before I knew about #1 arcing, and I haven't ridden the bike since I discovered the issue. As far as I can tell the arcing only happens below 1500rpm and at a rate of 1-2 arcs a minute, when the bike goes above 1500rpm there is no sign of arcing visible at the coil or in the form of misfires coming from #1. It's a strange issue but working on the bike wouldn't be nearly as fun without a little circumstance.
Offline Desert Dan
« Reply #80 on: May 24, 2015, 03:46:42 PM »
   Small update, Ive fixed the sparking #1 plug wire, raised my floats to 25mm, and installed new #35 slow jets. The plug wire was an easy fix all I had to do was pull out the old wire and insert a new one, it took a pretty hardy pull but I now know that I can easily change plug wires on my modified coils. Im not sure if Im setting the float levels correctly as I don't have the proper float level tool, I just use a card stock ruler that comes in VW carb rebuild kits. I'm unable to use the clear tube method to check the bowl levels because my drain screws have been seized in the bowls since day one, I believe it may take drilling out the old screws and tapping the bowls to get new drain screws installed. With that said the carbs no longer piss fuel from the vent tubes when the gas is turned on so Im on the right track. I cant report any changes with the #35 slows yet as it's been too cold and rainy in Colorado to go on any sort of test ride, but Im getting pretty close with the jetting as the engine now likes full choke and a little throttle when starting cold, where as before 3/4 choke was the max without becoming too rich to start.
Offline riverfever
« Reply #81 on: May 24, 2015, 04:05:12 PM »
So nice to have someone else tuning that's in a similar situation as I am. The weather we're having right now absolutely sucks. I'm still running 100/40 jets but that needle clip adjustment really helped things out so thanks for the suggestion. You have much more experience than I do. I took mine around the block today and it really struggles right off idle. I still need to change the filter out but I pulled some plugs when I returned. All 4 headers are very hot which is great b/c last year 4 was ice cold but plugs are really rich. I suspect I may need to make a slow jet change but I'd like to do a plug chop for the mains before that. Keep at it Dan. Maybe this summer if it stops snowing we can meet up for a ride.
Offline Desert Dan
« Reply #82 on: May 24, 2015, 04:25:09 PM »
Once the weather warms up a ride is definitely in order, the route to and around Colorado springs is one of my favorites, great roads and scenery all over. From the jetting charts I've scene on the forums there's not much to be gained from changing the slow jets as they are only effective up to a 1/4 throttle, I replaced mine in order to get better plug reads and to rule them out as an issue. I found changing the clip position helped most with getting up to highway speed with out struggling, but the most improvement came from dropping down in jet size. 4into1.com has the aftermarket replacement jets, they cary keyster jets which aren't held in high esteem on here but I found the jets marketed as reproduction keihin jets made by keyster fit better than the same part# keyster jets and also are cheeper. I don't know why this is but the regular keyster jets are $2.50 a piece while the reproduction keihins are $1.95 a piece. The regular keysters fit loosely in the carb bowl springs while the reproductions fit nice and snugly. Also the reproduction keihin slow jets by keyster are a dead match for the original keihin slows.
« Reply #83 on: May 24, 2015, 05:25:36 PM »
I'm in Briargate Dan. Drop by.
Online HondaMan
« Reply #84 on: May 24, 2015, 07:16:14 PM »
Yeah...when they fit loosely, or if the 'carb kit' for rebuilds came with the too-thin O-rings for the jets, they let too much fuel slip by. This really confuses things!
Offline Desert Dan
« Reply #85 on: May 24, 2015, 08:25:57 PM »
That sounds good Jerry, I believe RiverFever is just outside of Woodland Park so I can swing by when I go for a ride with him and we could all do a cruise through the Colorado springs area.
I originally got the standard Keyster jets when I tried the 98 jets and I had to use my own O-rings on them as the supplied ones were to thin and the jets themselves were very loose in the retainer spring jet holders, I used the reproduction Keihins when I went down to 92's and they came with the correct size O-rings and fit extremely well in the retainer springs. It's strange that Keyster makes two types of the same jet yet the cheaper version works best.
Offline Desert Dan
« Reply #86 on: May 26, 2015, 05:36:43 PM »
Well there was finally some sun in Colorado the last two days so I have been racking up the miles on the 500. I did 60 miles yesterday and 125 today, I am extremely pleased with the way the engine is behaving. Im getting really close with my jetting my idle jetting is spot on and so is my top end jetting I have to do a few plug chops on the mid range to see if I need to change clip positions then Ill toss in some new plugs to get down to the real fine tuning. My best MPG over the last two days was 43.2mpg which is a substantial increase from my old average of 37mpg when I was running the 40 pilot jets and the 22mm float heights. Just to recap as the bike sits right now the carbs are running 92 mains 35  pilots and the needle jets are set in the middle clip position. I have the timing set a few degrees more advanced than the standard timing mark and I modified the mechanism to advance a few more degrees at full advance. The bike is running beautifully right now and is nearly read to make some long distance trips around Colorado.
Offline riverfever
« Reply #87 on: May 26, 2015, 05:46:18 PM »
That's great Dan. I was amazed this morning when I drove down the pass on the way to work and saw blue skies and sun. I got out a little bit yesterday and tuned a bit (I moved the clips up one more spot and it seemed to really help around 1/4 throttle). Congrats on the progress. It's a good feeling.
Online HondaMan
« Reply #88 on: May 26, 2015, 07:39:43 PM »
You got sunshine?
I'm still  pumping out my bike sheds and back yard.
...and drying out motorcycle parts, like engine cases, that got drowned...
Offline Desert Dan
« Reply #89 on: May 26, 2015, 07:48:09 PM »
Thanks Chris, I was amazed at the amount of sun there was these last two days. I got rained on a little monday, but today It was clear skies with all the clouds hanging out up north. Ive been batting around the idea of movie up a clip position, I may do it next time I have the rack of carbs off, my only concern is it would throw off my low and high range jetting forcing me to jet up.
Offline Desert Dan
« Reply #90 on: May 26, 2015, 07:51:13 PM »
You got sunshine?
Im sorry to hear that Mark, I have some friends from school who live a few blocks from you and most of their basement has flooded from all of the rain. I wouldn't say it was all sun shine, I merely followed the clear skies south east where the clouds weren't hanging out.
Offline riverfever
« Reply #91 on: May 26, 2015, 07:55:34 PM »
I hate pulling the carbs off. I moved the needles with the rack on the bike. We've been getting hammered since I got home so I haven't done anything else.
Offline Desert Dan
« Reply #92 on: May 26, 2015, 08:08:02 PM »
Pulling the carbs is my least favorite job, Ive done it so many times since I bought the bike Ive got the process down to a two hour job to get the carbs off torn down and back on the bike. When you did the needles on the bike did you have any issue getting the slides out of 2&3? It would be a huge time saver not having to pull the rack for the needles.
Offline Desert Dan
« Reply #93 on: May 26, 2015, 09:00:20 PM »
I finally got ahold of the previous owner for some before pics of the 500
Here is how he bought it
Here it is after his restoration
And after I got ahold of it
You can see why I thought it would only need a quick tune up to get it back on the road, but I had no idea how much work I would be putting in to it when I bought it. I still need to rebuild the forks and replace the worn out fork gators but its 98% of the way there
Offline riverfever
Re: High altitude 73 CB500 daily driver (Now with before pictures)
« Reply #94 on: May 27, 2015, 02:01:16 PM »
Dan...Cal was the one who originally suggested that I do it that way in the efforts of saving time. Getting those tops off the carbs (particularly the inner screws of 2 and 3) was a royal PITA. You cannot get a Phillips screwdriver on those. I ended up using a the bit from a multi-screwdriver carefully placed in the screw. I then used a finger to press that bit down and then used a 1/4" wrench to turn the bit. Worked great. Removing the slides wasn't horrible. It was definitely worth the effort. I hate wrestling with that stupid airbox and the boots.
Offline Desert Dan
« Reply #95 on: May 27, 2015, 03:30:48 PM »
I took a look at doing that today but I didn't think of using the bit trick you described so I just left well enough alone. I cleaned my spark plugs with this nifty 80's spark plug cleaner I have laying around my shop, its this little black box that hooks on to a 12v battery, it basically sandblasts the plugs using graphite and does a half way decent job of cleaning them. I combine that with a little acetone and I can get 99% of the carbon off of the plugs. Im going to wait and accumulate a few miles on the plugs before I decide if I need to mess with my mixture any more, at the moment it seems to be running just right.
Offline Restoration Fan
  • My wife will never call me
« Reply #96 on: May 27, 2015, 03:50:21 PM »
Sorry to hear you guys are having bad weather.  It's been over 80 hear for a few weeks.  ::)
« Reply #97 on: May 27, 2015, 06:25:17 PM »
Sorry to hear YOU are having bad weather. 70's, sunshine, calm winds but the humidity is way up to 24% today. Now THAT sucks. I like our usual 15% much better. That even kinda eliminates mosquitoes. Aren't they the GA state bird ?!  ;)
« Reply #98 on: May 27, 2015, 06:45:32 PM »
:)  Not where I live, Jerry.  It actually has been humid here.  But nothing a little wind therapy won't cure!
Offline Desert Dan
« Reply #99 on: May 29, 2015, 05:40:10 PM »
   After cleaning the plugs Im getting a much hotter spark now and the bike has decided it wants to run lean  ::) . It gets pretty hot now, and under hard acceleration I get a bit of backfire, under high load and low rpm I sometimes hear a little popping coming from the carbs. Im thinking I need to bump the mains up to 94's and bump the idles to 38's. It makes cense to me now that Im running lean as the 92's didn't give me an increase in power over the 98's. Besides that Ive now got 900 miles on the top end and it hasn't sprung a leak on me yet.
