75 CB550. Oil leak.
I did a complete re-seal last summer. New head gasket, base gasket, and everything in between. Put it all back together and now I'm leaking oil. I traced it the best I could. Baby powder trick and all.
Here's what I've concluded to be the culprit: 3 of the bolts that hold the cylinder down just spin and spin. They are new oem bolts, so that means the threads inside the cylinder are stripped. That means oil coming through, and that means need a new cylinder.
Me and the little lady are closing on a house next week, so new cylinder is out of the question for a while. Here's the part you'll hate...
Since I'm going to get a new head cylinder at some point, how much can I mess with this broken one? Can I pull the stripped bolts out and cover them in loctite or something? Use a millimeter thicker bolt and drive it home? Does anyone have a head cylinder sitting around they could send my way?
Spring is just around the corner. I'm broke, but I want to ride.
