Author Topic: Oil pressure and temp  (Read 4046 times)
Offline Paul Lowe
  • If you like then it is good...
« on: February 21, 2015, 09:22:40 PM »
Have just completed a rebuild and everything seemed fine.
CB750 K1. Only got 100km since rebuild. When cold pulls hard runs well and oil pressure at 60-70psi (gauge). After a while oil pressure drops to 20-40 city traffic and oil light comes on. Bike starting to run rough but not too bad. Measured oils temp in tank after about 10mins and got 97 deg C.
Questions:
what is normal oil pressure range?
What is normal oil temp range when hot!
Will oil get thinner when hot and reduce oil pressure?
Is this temp just symptomatic of tight engine?
My Honda sickness deepens
CB350F 1972
CB360G 1974
CB750 K1 1971
CT90 K0 1968
C102 1963
C50 1968
C70 1972
C90 1974
CL90 1968
1/2HP electric bike home made...
Online PeWe
Re: Oil pressure and temp
« Reply #1 on: February 22, 2015, 03:00:01 AM »
Are all important O-rings replaced?
The o-rings on oilpump and the oil transportation from pump all the way to head?
There is a thread about important forgotten o-rings that can be replaced with engine in frame. http://forums.sohc4.net/index.php?topic=78643.0
Which oil? Maybe too thin? Motorcycle oil 20W-50?
Should no be temp. I ran my engine hot last summer, up to 110*C without any oil pressure lamp on idle
Offline Whaleman
« Reply #2 on: February 22, 2015, 04:51:14 AM »
20-40 when hot is good. You must have a gauge. The light should not come on when gauge is 20 psi. Either gauge or sender is defective. I have a sump temp gauge. You have 206 deg F while I have seen 250 deg F many times. Dan
« Last Edit: February 22, 2015, 04:54:33 AM by Whaleman »
« Reply #3 on: February 22, 2015, 05:06:34 AM »
What oil do you use?
But Whaleman is right, 20 - 40 hot is excellent and the 60-70 at cold is what i get too.  The oil light sensor is at around 7psi.
I run 20W-50 in summer and after long run - like 500 miles - the light would come on at idle, but thats an extreme.
Offline Paul Lowe
« Reply #4 on: February 22, 2015, 12:37:03 PM »
I believe I did all the o rings. Oil 10W-40. Over pressure sensor original gauge brand new.   Both gauge and sensor in oil gallery.
Have checked under rapper covers and there was plenty oil on start up.
CB350F 1972
CB360G 1974
CB750 K1 1971
CT90 K0 1968
C102 1963
C50 1968
C70 1972
C90 1974
CL90 1968
« Reply #5 on: February 22, 2015, 01:46:42 PM »
Well isnt it summer where you are?  20w50 is better for the engine in hot weather.
Online Bodi
« Reply #6 on: February 22, 2015, 01:54:49 PM »
As mentioned, the oil pressure switch is basically a "whoa stop engine now!!" indicator that oil pressure is near zero. It should turn off below 10psi, on at maybe 5psi. If it's on with 20psi measured, you need a new switch as it may really fail and start leaking soon.
Offline bytio
« Reply #7 on: February 22, 2015, 02:59:05 PM »
Honda manual shows 49 psi, at 60deg C  (oil temp) and 3000 rpm
Offline Paul Lowe
« Reply #8 on: February 23, 2015, 02:10:52 AM »
Thanks guys. Maybe a new pressure switch is the go. Does it have to be Honda as they seem expensive? 4into1 have an after market for US$15.75 which seems OK.
Any other suggestions?
CB350F 1972
CB360G 1974
CB750 K1 1971
CT90 K0 1968
C102 1963
C50 1968
C70 1972
C90 1974
CL90 1968
« Reply #9 on: February 23, 2015, 02:49:13 AM »
Heavier oil. 10W40 is not heavy enough for your summer,  maybe in winter and still your engine would be happier with 15W40.
For summer 20W50 and your engine will last longer.
« Last Edit: February 23, 2015, 03:13:30 AM by 70CB750 »
Offline chewbacca5000
  • I polish covers!
« Reply #10 on: February 23, 2015, 08:03:23 AM »
+1  Had same problem as you and above thread fixed it.  O-ring and drill hub
Offline toolguy
« Reply #11 on: February 23, 2015, 10:41:07 AM »
inexpensive replacement oil pressure switch on EBay.  exact size replacement  and
 fits under the cover properly  $6.25 and free shipping. From Honda Accord
Made by Original Eng Mgmt,  part# 8008
http://www.ebay.com/itm/Engine-Oil-Pressure-Switch-Original-Eng-Mgmt-8008-/301509845078?vxp=mtr
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #12 on: February 23, 2015, 01:37:07 PM »
Yeah, you should be able to replace your oil sensor with a CIVIC or Accord sensor.
Just take it into your local auto parts store and match it up.
  • I polish covers!
« Reply #13 on: February 23, 2015, 02:57:02 PM »
I re-read your post and did some Google and what I found is that with modern oil coolers with a temp switch they are set to go off at 212F.  So running at 250F is way too hot IMO.  Doing the shift mod will increase oil pressure, shifting, and maybe even cooling.  An oil cooler could not hurt either.
Questions:
Should be 20 PSI at idle and 60 PSI running
It is good to have temp be less than 212F
Yes
Not necessary.
Also eliminating the factory casting flash around the cylinders and head greatly increase cooling as does adding an oil cooler.
