Author Topic: BHP belt drive tuning instructions ( Bill Hahn Products )  (Read 1365 times)
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« on: February 22, 2015, 03:15:37 pm »
anyone got some instructions for correct installation???
« Last Edit: February 22, 2015, 07:19:38 pm by Medyo Bastos »
Re: BHP belt drive tuning instructions
« Reply #1 on: February 22, 2015, 04:49:46 pm »
BHP??
Offline NalleyRacing
  • 1972 Cb750K dragbike Instagram: Drag_racer736
Re: BHP belt drive tuning instructions ( Bill Hahn Products )
« Reply #2 on: February 22, 2015, 06:44:48 pm »
Mr.ATP himself. I'd expect anything made by Sr to be top quality like RC, Yosh,etc..
« Last Edit: February 22, 2015, 10:52:25 pm by TreyAllen »
Offline johno
« Reply #3 on: February 23, 2015, 01:23:37 am »
Hi Medyo,
just like a dizzy in an old car!
put a degree wheel on the other end of crank ,
find TDC by piston for no 1. cyl .on compression ( both tappets loose)
 turn the crank forward until the desired degrees ( either or idle say 10 or max advance say 36 deg)  mark the spot.
 Install the drive and dizzy with rotor button pointing to no 1 cyl lead and the points just opening , use 12 volt light or cig paper or listen for spark crack at points to find the sweet spot.
Unless you know the advance curve etc it is probably easier to set the up to have points just opening at idle deg say 10 deg BTDC, also mark the max spark advance  point say 36 degrees you want on the pulley drive somewhere so you can use a strobe to check max deg advance  when its running.
Hell Medyo that sounds confusing doesnt it  :o.....pay some bloke $50 to do it , watch and learn ;) ;D
have fun mate.
ciao
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
Offline Jim F
  • go baby go
« Reply #4 on: February 23, 2015, 03:23:26 am »
Sounds like an updated version of an ARD
Magneto
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
