I can't find the thread that had a related topic, but I do recall that changing out the 10 crank supporting bolts with stainless ones was a big NO NO!
Other than that, does anyone have experience with, or would caution against, using all stainless replacements for the crankcase bolts nuts and washers?
Belmetric seems to carry all the flange type bolts in stainless so hopefully they'll be a direct replacement. As for the big 10, I've seen builds (Tige's K1 GT for instance) that use HD studs instead, so that solves it. Another thread that I can't find talked about what kind of antisieze to go with when using stainless hardware in the 750 Aluminum Alloy cases. IIRC, copper was to be used (some science about metal nobility and such). Want to be absolutely sure before buying anything, thoughts?
