Logo merchandise is available at the SOHC/4 Shop
For your reference mate, the stock stud lengths areLong Stud - 195mm OALShort stud - 170mm OALInstalled heightLong Stud - 170mmShort Stud - 130mmBelow are stock studs on APE HD studs for comparisonBelow are installed (stock studs) - 170mm and 130mm height from top of case.The best thing to do now is to Loctite the studs into the case and set the heights (above) as evenly as you can.It doesn't have to be a micro measurement, just get them as close as you can by eye with a steel ruler.The warning here is, don't flood the stud threads with Loctite.Lightly coat the threads in the case with a toothpick and then screw the studs into the case.Reasons being that too much liquid runs the risk of "hydraulicing" the stud in the threaded hole and secondly and most importantly, there's every chance that the oil galleries that let oil feed the top end will be blocked solid.If that happens, you'll be pissed off big time.
I'm not a fan of torquing a stud into it's hole. I was taught not to do that on my Chevrolet race engines. I know, apples and oranges.
