Author Topic: Typical front shock behavior  (Read 357 times)
Offline eigenvector
« on: March 09, 2015, 02:16:17 PM »
Having finally taken the thing out on the road, I noticed that the front shocks are certainly bouncy.  I'm comparing them to the way the shocks were before I rebuilt them - they were like steel bars.
Should the shocks be pretty bouncy or is there something wrong in there?  They aren't leaking anything that I can see anyway.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Re: Typical front shock behavior
« Reply #1 on: March 09, 2015, 02:28:06 PM »
under (controlled) hard breaking, do they bottom out?
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: March 09, 2015, 02:28:13 PM »
They should come back up slower then they go down.  If not, your rebound damping action is not working.
Did you change anything, or just disassemble/clean/reassemble with fresh seals?
mystic_1
- John Augustus Shedd
Offline eigenvector
« Reply #3 on: March 09, 2015, 02:29:42 PM »
Just did a thorough cleaning of all the internal parts.  They were pretty grungy and the fluid smells very burned.
Didn't think the check the rebound.  I'll go do that now and report back.
follow up:  Ehh, on second thought they aren't that bad.  I bounced them a few times and they seem to be behaving themselves.
« Last Edit: March 09, 2015, 02:32:14 PM by eigenvector »
Rob
1977 CB550K
1983 VF750S Sabre
