Author Topic: gas tank model clarification  (Read 729 times)
Offline racersnake
« on: February 27, 2015, 05:32:12 AM »
I've read all the threads I can find(sure im missing some) about how to tell what tank I have or need
here's the issue:
I have a 1974 CB550K and the seat tank have a large space between them , like a dummy I assumed it was a seat issue , but after getting a stock 75' K seat its the same!!
so it seems that my tank is the issue
So is the 500K tank smaller? if so how do I know the difference ?
It looks as though the Early 550 tanks have the same ,500 K petcocks , so that threw me off also.
any help greatly appreciated
Offline racersnake
Re: gas tank model clarification
« Reply #1 on: February 27, 2015, 08:15:10 AM »
ill post pic asap
Offline mronegear
  • Honda CB 550 F 1976
« Reply #2 on: February 27, 2015, 08:27:29 AM »
Hey!
I have the 550 f1 with stock tank and stock seat and i have also a little gap inbetween. Mine is not too big to worry about.
Offline Trad
« Reply #3 on: February 27, 2015, 09:00:32 AM »
The early tanks have an external chrome flip latch and are shorter. The newer tanks have a recessed filler point with a painted cover and these tanks are longer. I hope that helps.
« Last Edit: February 27, 2015, 02:02:27 PM by Trad »
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
Offline racersnake
« Reply #4 on: February 27, 2015, 01:26:02 PM »
it is clearly to big a gap, so are the 500 and 550 tanks different in length??
Offline racersnake
« Reply #5 on: February 27, 2015, 01:27:17 PM »
a couple more pics
you can see on the side shots were it comes to per the frame welds
Offline Trad
« Reply #6 on: February 27, 2015, 01:58:10 PM »
The 500 and early 550 tanks are the same. The one you have with the external filler cap and latch. The 550 tanks with the recessed and covered filler caps are longer.
If it truly is a 74, you have the correct style tank for the motorcycle.
Can you show me a link to the seat you bought?
« Last Edit: February 27, 2015, 02:02:48 PM by Trad »
Offline goldarrow
  • one day, i'll be an
« Reply #7 on: February 27, 2015, 02:09:12 PM »
The tank looks correct, but seat looks like off of different bike.  Post better pics of the seat
CB550 K0
Offline racersnake
« Reply #8 on: March 02, 2015, 05:29:41 AM »
Thanks for the help , yes after more research it seems both the seats I have are off newer 550's , hence being shorter
Thanks again
