Author Topic: How much torque to put on this screw?  (Read 946 times)
Offline Moosey
« on: March 01, 2015, 01:55:50 PM »
I am replacing some seals on the shifter section of my 1971 cb500. When I was taking apart the shifter mech under the clutch, I noticed that this screw was loose. When I put it back on and tightened it it seemed to bind the cam plate abit. How much torque do you put on this screw? It is shown in the pick below, I pointing to it with a screwdriver.
Offline Moosey
Re: How much torque to put on this screw?
« Reply #1 on: March 01, 2015, 03:36:32 PM »
And also for the 10mm bolt to the right of it that holds the arm. Thanks
Offline LesterPiglet
  • 1977 CB550F2
« Reply #2 on: March 01, 2015, 03:53:37 PM »
I don't think you can overtighten that screw by hand with a screwdriver. Put some loctite on it as well.
Offline Moosey
« Reply #3 on: March 01, 2015, 07:15:48 PM »
bump
Offline mystic_1
  • 1970 CB750K
- John Augustus Shedd
Offline Moosey
« Reply #5 on: March 02, 2015, 07:19:36 AM »
Any others have any input?
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #6 on: March 02, 2015, 08:00:07 AM »
If you can't find a torque rating in the shop manual use the standard metric torque values mystic suggested. Anything else is a guess.
