Author Topic: Is something wrong with my gears?  (Read 568 times)
Offline Moosey
« on: March 02, 2015, 04:30:48 PM »
I have a 71 cb500 and have the engine off the bike and clutch off. I put my shifter arm on and tried to shift thru the gears. Is it normal not to be able to shift thru all the gears with engine off the bike like that? It only seems to go into neutal and one other gear.
Offline mystic_1
  • 1970 CB750K
Re: Is something wrong with my gears?
« Reply #1 on: March 02, 2015, 04:37:54 PM »
Yes, this can happen because the gears aren't aligned quite right while you're trying to shift.  Try shifting while you rotate the final drive sprocket by hand, you'll probably find you are able to shift through all gears then.
mystic_1
- John Augustus Shedd
Offline Moosey
« Reply #2 on: March 02, 2015, 04:39:10 PM »
Thanks so much for the reply. I will try that out.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #3 on: March 03, 2015, 06:50:12 AM »
mystic_1
I've seen someone hook an electric drill up to their final drive to test this.
--Evan
1975 CB750K "Rhonda"
