Author Topic: 1972 CB500 - Rebuild Project  (Read 31092 times)
Offline Puffin
Re: 1972 CB500 - Rebuild Project
« Reply #50 on: April 04, 2015, 03:20:27 PM »
Here's the original rear shocks, cleaned up, painted and installed without the large upper cover.  I think they look a lot better without it.
Honda CB500 four
Honda CB350 four (under construction)
1972 Cb500 Rebuild Project - http://forums.sohc4.net/index.php/topic,145835.0.html
Offline Puffin
« Reply #51 on: April 04, 2015, 03:27:08 PM »
So that's me up to date.
I think today I will be finishing off the rear wheel assembly and I might see if I can get the bottom end buttoned up if I have everything I need.  I know I need to get the alternator rotor off the crank to change the seal so this might depend on whether i have the right sized bolt to force it off the spline.
Anyway I hope everybody is enjoying a long weekend off work  8)
Honda CB500 four
Offline Puffin
« Reply #52 on: April 08, 2015, 08:51:03 PM »
So to get the rotor off to change the crankcase seal I needed an M16 fine thread bolt.  I struggled to find this in the standard hardware shops however I took a drive to a specialist fastener supplier and he gave me this one... didn't even want any money for it!  Anything over about 20mm in length will work fine.
I screwed it in and give it a couple of sharp taps with a hammer and the rotor just popped right off.
Honda CB500 four
Offline Puffin
« Reply #53 on: April 08, 2015, 08:57:57 PM »
Got the crankcases all bolted up over the weekend.  All went together really easily.  I do admit I sat and stared at it for about 30mins before mating the two halves because I was so convinced i was going to forget something...???
I used a bit too much sealant on the cases, probably only needed a thin smear on one half rather than both halves.  It's not too excessive but it just looks a little unsightly where it's extruded out.  The Hylomar is Blue so it's pretty obvious... at least my dark grey engine cases hide most of it... (lol)
Any suggestions on cleaning the excess gasket sealer off the joins on the cases?  It's soooooo sticky and because it's non-drying it just spreads around? Carb cleaner maybe?
« Last Edit: April 08, 2015, 09:05:00 PM by Puffin »
Honda CB500 four
Offline Bootsey
« Reply #54 on: April 08, 2015, 11:55:01 PM »
Looking good! What's the plan for the paint scheme, keeping the current tank or something new?
Offline calj737
  • I refuse...
« Reply #55 on: April 09, 2015, 05:04:17 AM »
Use Acetone or Xylene to remove the excess Hylomar. Wet a rag and wipe, don't squish the fluid into the case seams as it will undo your seal.
Bear in mind, the excess showing on the outside of your cases, is also on the inside of your cases... If there's cause for concern of too much, best to part the Red Sea and clean it up lest the excess travel into your oil galleys-
Offline Puffin
« Reply #56 on: April 20, 2015, 09:50:03 PM »
Yeh this is what is worrying me.... I think I need to get the torch out and have a really good look inside.  I really don't want to open them back up now but I guess for piece of mind it's worth it.
Honda CB500 four
Offline Puffin
« Reply #57 on: April 20, 2015, 09:55:32 PM »
Hi Bootsey,
I have changed my mind several times already on the paint scheme and I'm sure I'll change it 100 times again before I get that far.  definitely going to keep the original tank however it will be fully stripped, prepped and repainted.
Originally it was going to be White, then black and white, then Repsol Orange, then I thought about a deep Burgandy-ish Red, now I'm leaning towards a classic Black or Dark Grey.  Tomorrow it will probably be British Racing Green like my old CB250...
Honda CB500 four
Offline Puffin
« Reply #58 on: April 20, 2015, 10:01:27 PM »
So progress has been a bit slow.  My new Cylinder Studs have been 5 weeks in the post which means my engine rebuild has stalled..  Unfortunately it looks like they have got lost however I can't make a claim until it's been at least 6 weeks.
In the meantime I've just been tackling random jobs.
I built myself a little vice-mounted polishing rig out of a free Bench Grinder and practiced on my engine covers.
« Last Edit: April 20, 2015, 10:33:57 PM by Puffin »
Honda CB500 four
Offline Puffin
« Reply #59 on: April 20, 2015, 10:08:38 PM »
I also built myself a wheel alignment jig that mounts to the end of the bike table and checked the 'trueness' (is that a word???) of the wheels.
They look pretty good.  I noticed there are a few new spokes so somebody must have had a go at restoring these already.
Honda CB500 four
Offline Puffin
« Reply #60 on: April 20, 2015, 10:23:00 PM »
Got the new piston Rings on and installed the pistons.  These were from the 'Cruzinimage' eBay seller and were delivered within a couple of days all the way from Japan.  The instructions are a bit redundant though as both the first and second rings have just an 'R' stamped on the upper side... not the 1R and 2R as shown on the packet.
From what I worked out the 'Chrome" ring goes at the top and the "Matt" ring is the second ring down.   You can also tell by the slightly different cut to the outer edge.  The top ring is beveled whereas the second ring has more of a tapered outer edge.  Somebody please feel free to correct me if I have this wrong.
I also got the Gear Shift mechanism and Clutch installed.
Honda CB500 four
Offline Puffin
« Reply #61 on: April 20, 2015, 10:31:48 PM »
Ordered a new set of Dunlop K70's.
I wanted something Retro, suitable for touring and in the correct imperial sizes so these ticked all the boxes.  There are a lot of New Zealand roads that are still unsealed as well so something with a bit of tread is going to come in handy for my big tour around the country early next year.
I think they will suit the look I'm going for.
Honda CB500 four
Offline Bootsey
« Reply #62 on: April 20, 2015, 10:38:06 PM »
Looking good.
It sounds like you've got the rings sorted, here's some confirmation from the manual for you.
Offline Puffin
« Reply #63 on: April 22, 2015, 04:31:07 PM »
New tyres arrived and look awesome...
Dunlop K70's, 4.00x18 rear and 3.25x19 front
Managed to puncture the inner tube on the front with the tyre irons which is really annoying.  Must have got pinched at some point.
What's the deal with patching these inner tubes?  Seeing as they run at less that 30psi I can't imagine that it's much of a problem, especially considering a bike tyre runs at double that.  I guess the speed and weight of Motorbike is a lot different however.
Anybody have any opinions?
What about balancing?  I've spun the rear tyre a few times and the valve always ends up at the bottom which implies I need to apply a small spoke weight opposite.  Am I thinking about this too much or is it good practice to try and balance the wheels out?
Honda CB500 four
Offline Puffin
« Reply #64 on: May 07, 2015, 07:19:13 PM »
Looks like my Cylinder studs have been officially lost in the post... I did get a refund but unfortunately the place I ordered them from are now out of stock and I am really struggling to find somewhere else to get them from who will also post internationally.
I guess I just have to wait till they are back on the shelf.  This is really slowing me down however there is always something else to be getting on with.
I have the wheels on and assembled the rear brakes so at least i now have a rolling frame.
Honda CB500 four
Offline calj737
  • I refuse...
« Reply #65 on: May 07, 2015, 07:20:28 PM »
APE just made new sets, carried at dynoman.net
Offline Puffin
« Reply #66 on: May 07, 2015, 07:40:47 PM »
Thant's good to know.. thanks Cal.  Hopefully the usual suppliers will be getting re-stocked soon
I have tried Dynoman but they want $60USD for shipping..... it's only really viable for me if I can chuck a load of other stuff in and combine shipping.
Honda CB500 four
Offline Puffin
« Reply #67 on: May 07, 2015, 07:54:04 PM »
I cut down the front fender as well.  Pretty pleased with how it turned out.
Honda CB500 four
Offline calj737
  • I refuse...
« Reply #68 on: May 07, 2015, 07:58:07 PM »
Ship them to me stateside. I'll post them to you via US Postal Service. Whole affair should be less than US $20.
Offline Puffin
« Reply #69 on: May 07, 2015, 08:02:02 PM »
You Sir.... are a Gentleman.
I will PM you and get your details.
Honda CB500 four
Offline calj737
  • I refuse...
« Reply #70 on: May 08, 2015, 02:15:19 AM »
Shhh! Don't spread that about for Pete's sake; I have a reputation to protect  >:(
Offline Puffin
« Reply #71 on: May 25, 2015, 04:13:44 PM »
Finally got my new cylinder studs through...!   ;D
The Honda Service Bulletin 500#3 from 1971 states that replacement studs should have Locktite applied and then the studs should be torqued to 14.5-16.6 ft.lbs
Instructions from APE however are different and as follows:
CS500H CYLINDER STUD INSTALLATION INSTRUCTIONS
1. Long threaded end must be installed in the case.
2. Note stock stud length location before removing. There are two different stud lengths.
3. After removal of stock studs (removal tool #SP-100 available from APE) thoroughly clean holes with solvent and blow out.
4. Use APE stud installation tool #08-151 or two 8x1.25mm nuts on the noted location, bottoming out, then using a torque wrench torque to 8 ft. lbs. maximum.
4. Install head, and following manufacturer's torque pattern, torque nuts to 20-22 ft. lbs.
Given the Service Bulliten is 45years old I went with the APE method.....
« Last Edit: May 25, 2015, 04:17:35 PM by Puffin »
Honda CB500 four
Offline Puffin
« Reply #72 on: May 25, 2015, 04:39:55 PM »
Stripped the horrible flame-effect tank back to the bare metal.
There were about 4 or 5 layer of paint on the thing so it was a little work but I was generally pleased with the condition of the tank underneath.  There is a small ding by the right tank badge which had some filler in which will need addressing if I decide to paint.  Right now I really like the bare metal...  I might just black zinc the underside and then lightly sand out the scratch marks and give it a polish and an oil or a wax.
Honda CB500 four
Offline Puffin
« Reply #73 on: May 25, 2015, 04:44:23 PM »
Also finished off my side covers... My technique was definitely getting better as I practiced more.  Really pleased with the last piece even though the shape made it pretty awkward.
I'm not going for show-room here.  The few pits and blemishes give it some character...
Honda CB500 four
Offline Restoration Fan
  • My wife will never call me
« Reply #74 on: May 25, 2015, 05:40:31 PM »
The polishing looks good.  Even though it's a pain in the butt, when you bring those old parts back to looking like their original new self, there is something very satisfying about the process.  Almost makes the paint in the butt part seem not so bad, huh?
