Author Topic: exhaust wrap or something else? Best finish for pipes  (Read 2678 times)
Offline ncstatecamp
« on: March 11, 2015, 10:06:07 PM »
So I need to do something about my exhaust, its damn rusty (surface nothing flaky or deep). I moved to Chicago just before winter and the salt reeked havoc on my finish (VHT paint flaked off while back). So the paint didnt work well for me, would exhaust wrap work better or be worse for rust? what are my other options?
Offline brewsky
Re: exhaust wrap or something else? Best finish for pipes
« Reply #1 on: March 12, 2015, 03:25:53 AM »
I have used this with success in the past (in silver).
Prep is probably key to results.....I used wire brush, sandpaper, and brake kleen first.
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #2 on: March 12, 2015, 05:29:10 AM »
Similar... I used VHT Hi-Temp header paint (flat black). I used their primer first, but didn't wait long enough to add the black coat, so it chipped with the heat. I'm wire-brushing it back and doing the black coat again.
--Evan
1975 CB750K "Rhonda"
« Reply #3 on: March 12, 2015, 05:42:59 AM »
A ceramic coating would be your best bet.
Offline calj737
  • I refuse...
« Reply #4 on: March 12, 2015, 05:47:37 AM »
This is the best option. Costing the pipes inside and out protects them the most, and provides some performance gains. Look around at your local automotive powder coaters. Many also offer ceramic coating products. Pipes get sand blasted inside and out to create the proper surface adhesion, then the ceramic is applied in a dry powder form, then baked to cure. Surface grime wipes right off, even salt.
The downside to the exhaust wrap is that it actually traps moisture and heat between the wrap and pipe, accelerating corrosion.
Offline Chachi
« Reply #5 on: March 12, 2015, 07:17:12 AM »
I'm planning on ceramic coating my headers soon. I didn't have the best luck with high temp can paint. It was probably in the prep (removing all old chrome). To best prep for paint you would ideally need to have it blasted... and if you're doing that, you might as well ceramic coat as you're halfway there. But it's not cheap. I'm not sure how my local rates compare, but my quote is in the $250 range for 4-1 header. If you have the money, ceramic. If not, prep by hand as best you can and paint it for a season/year until you can ceramic. And I've seen some high temp can paint jobs last fairly well, but mine didn't. I'm going for black, but here there are some 'silver' ceramic options out there too if you want it to resemble chrome.
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
« Reply #6 on: March 12, 2015, 07:52:14 AM »
I was quoted just under $200 for ceramic on a 4:1 header.
8 different colors at the place in my area.
http://www.performancecoatings.com/index2.html
Offline Powderman
« Reply #7 on: March 12, 2015, 08:39:28 AM »
Ceramic is not applied in a dry powder form it is a wet application just like paint. Most of the new ceramics are air dried and don't require curing in the oven. The only upsides to exhaust wrap on a bike is some heat shield protection on your leg (it still  gets plenty hot), and cosmetic (eye of the beholder). There's no performance gain from it and as mentioned it accelerates the rust issue.
Offline calj737
  • I refuse...
« Reply #8 on: March 12, 2015, 09:27:16 AM »
While it seems I was mistaken about the "dry powder" aspect, the products my service guy uses do indeed require baking-
http://www.techlinecoatings.com/hi-performance/bs-exhaust-system-coatings.html
Offline ncstatecamp
« Reply #9 on: March 12, 2015, 11:06:10 AM »
When I did the vht paint I sand blasted the pipes, cleaned em, then painted them but it still chipped off. So basically my options are looking like getting them blasted again and either cermic or powder coated...
« Reply #10 on: March 12, 2015, 11:16:44 AM »
It depends on your budget and how long you expect the exhaust to last. Wrapping can look a bit ghetto.
Powder and Jet hot are an option. You can also just repaint and when they get flaky, just respray.
Offline ncstatecamp
« Reply #11 on: March 12, 2015, 12:08:36 PM »
Is there any kind of seat I can do to the wrap? I think ive read somewhere of people coating the wrap in VHT or silicone or something...
« Reply #12 on: March 12, 2015, 12:21:37 PM »
My Kerker header had road rash on one pipe, but was still in good condition.
I had it blasted, coated in VHT, and then wrapped it w/ DEI black header wrap.
I coated the wrap, as suggested, with DEI silicon header paint.   2 years and it still looks great.
Offline ncstatecamp
« Reply #13 on: March 12, 2015, 12:38:21 PM »
Any pictures? And any idea how its looking underneath?
Offline calj737
  • I refuse...
« Reply #14 on: March 12, 2015, 12:54:16 PM »
Underneath and inside are the questions...
« Reply #15 on: March 12, 2015, 01:00:49 PM »
Ride long enough and there will be less chance of rust as the heat dissipates the moisture.
Whenever I take the header off for a filter change, I can touch up...
Offline EricHa
« Reply #16 on: March 12, 2015, 01:45:01 PM »
I had VHT high temp paint that was pretty tough, but made sure to have the surface super clean and slowly warmed the pipe. I wound up wanting ceramic so I sent her to Jet-Hot last month. It has a beautiful finish.
1975 Honda CB550K1
1976 Honda CB750K6
1977 Kawasaki KZ900A5
« Reply #17 on: March 12, 2015, 01:50:00 PM »
Looks great!  8)
« Reply #18 on: March 12, 2015, 04:27:53 PM »
Looks great!  8)
+1. Mind if we ask what they charged you, Eric?
Offline EricHa
« Reply #19 on: March 13, 2015, 08:29:37 AM »
Looks great!  8)
It was $215 plus the return shipping. The total with shipping both ways is pricey but not nearly as expensive as chrome and it does look nice.
1975 Honda CB550K1
1976 Honda CB750K6
« Reply #20 on: March 13, 2015, 09:34:07 AM »
Looks great!  8)
That is a very nice looking finish. Deeper than chrome, more like the polished Aluminum. You did a great job on the motor, looks great.
« Reply #21 on: March 13, 2015, 07:41:45 PM »
Looks great!  8)
Sounds like a fair price.
Offline Airborne 82nd
« Reply #22 on: March 13, 2015, 08:01:53 PM »
Best of the best. Bar none.
http://www.jet-hot.com/coatings/
Offline Powderman
« Reply #23 on: March 14, 2015, 09:04:08 AM »
We get between $17.50 and $22.50/lf for doing Ceramic. That will get you a ballpark on what yours should cost.
Offline ncstatecamp
« Reply #24 on: March 14, 2015, 09:08:12 AM »
So a 4 to one would be 9ish ft so ball park $180?
