Author Topic: 400F clutch adjuster needed  (Read 862 times)
Offline nvr2old
« on: March 15, 2015, 12:19:48 PM »
Does anyone have any idea of where to get this clutch adjustment part for my '75 400F?  This one is solidly locked into  the cover and will not turn with a wrench even after soaking it in penetrating oil. I'm all out of adjustment at the handle bar so I need one on hand before trying anything more drastic to remove the original.  Thanks in advance.
'76 CB550F-'72 XL250-'82 MB5-'82 CX500 Turbo-'77 naked Goldwing-'75 CB400F cafe'-'79 Suzuki GS1000S..hey, it's a Wes Cooley..
Offline MoMo
  • Ride like you're invisible
Re: 400F clutch adjuster needed
« Reply #1 on: March 15, 2015, 04:51:28 PM »
I think David Silver Spares sells the part...Larry
Offline nvr2old
« Reply #2 on: March 15, 2015, 06:26:23 PM »
They were the first place I checked, unfortunately, to no avail.  For such a simple part, it's been hard to locate.  Thanks for the reply, though.
Offline eastyork1977
  • Tuning and building in the Great White North
« Reply #3 on: March 15, 2015, 06:44:43 PM »
Two pairs of vice-grips should do it. Also try tightening or tapping it to shock the threads.
'73 CB350G
'75 CB400F
'77 CB550K3 "Swayze"
'78 CB550K Stock
'78 CB750F2 Stock-ish
"take a peak." - Don Cherry
"If I can bounce a wrench off a tyre and it hits you, you're standing too close."
« Reply #4 on: March 15, 2015, 07:06:15 PM »
 When I needed one there were a couple new ones on Ebay. I was going to make it from a bolt but found it first.
   I've had good luck tapping on the top, then add tension to the bolt while tapping on the outside of the aluminum with a soft hammer. Not hard enough to dent it, just shock the metal. It almost always unscrews, you have to know when to stop and repeat. 6 point wrench for sure. And I like seafoam penetrating oil, I've had good results using it even after Kroil didn't work.
Offline kfleschner
« Reply #5 on: March 15, 2015, 09:37:43 PM »
You'd have to buy a whole new cable, but would this work?
http://4into1.com/honda-cb400f-clutch-cable-1975-1976/
Offline nvr2old
« Reply #6 on: March 16, 2015, 09:43:55 AM »
Thanks very much for that link.  Yes, that would be doable even though I have a new cable already installed.  I appreciate the replies.
Offline rockvegas400
« Reply #7 on: March 16, 2015, 04:44:13 PM »
I got mine from here a few years ago. At the time Silvers did not have access to the part. Prompt service, a reasonable price, and they didn't hit you with huge postage.
http://www.phildentonengineering.com/
1975 CB400F
1988 VFR750F-J
Offline przjohn
« Reply #8 on: March 16, 2015, 04:54:42 PM »
That is what I had to do. The fitting was impossible to get out even with a left hand bit. Ended up drilling it out, Helicoiling the thread and using the 4 into 1 cable.
