Author Topic: 1978 cb750 Cylinder head swap question  (Read 2414 times)
Offline arncruz
  • 1977 cb550
« on: March 15, 2015, 06:33:19 PM »
I have 1978 CB750K motorcycle that I bought recently and was able to get it started.  However, after the first start, I noticed oil leaking from the bottom.  after close inspection and removal of years of oil build up, I find a crack in the crankcase right adjacent to the main sprocket.  It was probably from loose chain hitting the crankcase.  Regardless, I was able to find a parts bike but it is a 1978 cb750F.  The crankcase looks good so far but the cylinder head has several broken fins.  My question is can I swap the CB750K cylinder head and place it on the crankcase and jugs of the cb750F engine?  Has anyone done this swap?  I tried to do a search on the forum but no results.
Thanks for any help in advance.
My Stable
1969 CB750 #6xx
1969 CB750 #20xx
1969 CB750 #27xx
1969 CB750 #43xx survivor
1969 CB750 #12xxx
1970 CB750 K0 survivor
2014 MVP Agusta 675 F3
Offline hsas.69
Re: 1978 cb750 Cylinder head swap question
« Reply #1 on: March 15, 2015, 07:05:33 PM »
Should work no problem.
78 CB750 F3
78 CB550 K4
Offline Old Scrambler
« Reply #2 on: March 15, 2015, 08:40:50 PM »
except the pistons WILL hit the valves ;) ;) ;)
If you switch the pistons and closely watch the o-ring placements, the K-head can be set on the F-jugs..........but check the oil flow to the head before you run the motor. The F oil feed is different.
P.S. - If the crack in the cases is just that, it could be repaired............ :)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline arncruz
  • 1977 cb550
« Reply #3 on: March 16, 2015, 12:48:33 AM »
I finally got the donor engine from a parts bike I bought and  I took a closer look to see if there was any oil leaks which I did not see.  However I did see a small crack on the top crankcase by the clutch.  I don't see any oil marks or seepage around the crack.  I'm wondering if I need to replace this too.
My Stable
1969 CB750 #6xx
1969 CB750 #20xx
1969 CB750 #27xx
1969 CB750 #12xxx
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #4 on: March 16, 2015, 04:26:32 AM »
How bad are the broken fins? I might be inclined to run the F motor as-is and repair/rebuild the K motor.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline CB750F2
  • Pat's first Honda 750 F2
« Reply #5 on: March 16, 2015, 05:28:05 AM »
The domed shaped pistons of the F will hit the valves of the K head and also the four of the oil drain back holes of the F cylinders will need to be modified to allow the oil from the K head drain back to the crankcase. You will avoid all this if you install the head, pistons and cylinders from the K motor. However, as Old Scrambler has suggested why not repair your K crankcase. The crack on the F can be repaired as well.
A temporary repair of your K crankcase can be done using JB Weld. Pat
Regards
Pat from Australia
Offline koendd
« Reply #6 on: March 16, 2015, 06:05:42 AM »
do make sure you use the K pistons and modify the F cylinders oil return as said before.
I ran my F2 for about a 1000miles when I took it apart to install new pucks due to oil leak.
turned out I had a K head on F cylinders/pistons. (nothing modified)
also F2 cam.
result was a burned cam and valves hitting the pistons (valves were not bent though...)
it actually ran great but not sure how much longer that would have been the case..
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
Offline arncruz
  • 1977 cb550
« Reply #7 on: March 16, 2015, 08:27:03 AM »
madmtnmotors, I like that idea.  I will probably do that and repair the K engine.  The fins are not too bad looking as I thought.
My Stable
1969 CB750 #6xx
1969 CB750 #20xx
1969 CB750 #27xx
1969 CB750 #12xxx
« Reply #8 on: March 16, 2015, 10:17:08 AM »
I usually drop the oil pan and make sure the oil pump screen is clear as cheap insurance before pressing a used mill back into service. It can also be an indicator of the condition of the engine internals. I've cleaned some pretty nasty/gloppy screens and the engines ran well, just not so much if the pump screen is "all choked up"!  ;)
TAMTF...
Wilbur
Projects:
Offline hsas.69
« Reply #9 on: March 17, 2015, 06:01:21 PM »
Sorry for the miss information. Didn't realize the dome was that large on the F pistons.
78 CB750 F3
78 CB550 K4
