Yes, my suggestion was to cut off that thick portion of the grip. And yes, you'd have to trim the throttle tube as well. No biggie, i've done it before so there is minimum gap between the grip and the control.
Not sure if this is your best option but just wanted to throw it out there.
My throttle grip is 4.5" long. As for the binding, there needs to be clearance between the inside end of the grip and the throttle housing.
Did you use light lube under the throttle sleeve? There should be NO resistance or binding of the throttle sleeve. Mine has play in all directions. Up to but no more than 1mm in any direction...even rotational play, before the cables 'engage'.
Find out where your throttle is binding. omitting it might help your spacing.
That foam/neoprene ring seems hokey
Is it causing your poor throttle return?
I think I worked it out.
On the spacing... Slid the brake clamp just a little further on, protected the wires coming from the switch housing with some gorilla tape and wedged the throttle housing up a little tighter, and removed the neoprene disk (yeah, it was "hokey"), and it all seems to fit. Didn't end up having to trim anything, and was able to create just enough spacing at both ends of the grip.
But, throttle was still tight... Lifted the tank and found the cables had been caught somehow between the its rubber mounting posts and the tank "c" brackets...probably for years.
![Huh ???](http://forums.sohc4.net/Smileys/default/huh.gif)
One was chafed right through the inner sleeve. Opened up the throttle housing and found the push cable had been pinched between the two halves. Frayed with half the strands broken. Not sure if I did that or someone else previously. Time for new cables! Is Motion Pro the right choice? Without the cables attached, the throttle grip turns just fine!
![Wink ;)](http://forums.sohc4.net/Smileys/default/wink.gif)
If I'm to lube it, will 3 in one work?
And the brake banjo... It's still rotated forward for now, but not useable that way. Original rubber hose is too long. With shorter, it looks like I could rotate the banjo about 90 deg toward the rear and let the line drop just over the headlight ear for almost a straight shot to the brake switch fitting on the lower triple. Also, with the tight bend I noticed some cracking. Replacements will be stainless steel brake lines. Recommendations? Slingshot? Goodridge? Galfer? Any others?
Thanks for all the observations and suggestions. It's great having guys like you to lean on for my first go at an old bike.
Mark
