Author Topic: Making my bike roadtrip worthy  (Read 1131 times)
Offline cbfivefitty
« on: March 20, 2015, 04:34:05 PM »
Hey guys, ive been slowly bringing this cb550 back to life and thanks to this site ive finally gotten it back on the road for some short rides! in a little less than a month however me and my dad are taking a weekend camping trip with our bikes. its a 130 mile trip each way plus riding throughout the weekend. I would really enjoy that weekend better if the bike does'nt break down so im trying to compile a list of things i need to do before that trip. So far im thinking
Oil change
new clutch and throttle cables
something with the suspension maybe new fork seals and fluid idk..
i was also thinking of lubing some moving parts, the swing arm, im not sure if im supposed to lubricate the axles at all.
id like to test the charging system to make sure its recharging the battery so i can get home...
new spark plugs
thats really all i got so far. im new to motorcycles still and i was hoping maybe you more seasoned riders and builders could give me some ideas and tips for making this ride there and back with the bike in one piece.
Re: Making my bike roadtrip worthy
« Reply #1 on: March 20, 2015, 04:58:18 PM »
When was the last time it had a full 3000 Mike tune up?
If you don't know, it is time.
« Reply #2 on: March 20, 2015, 05:36:37 PM »
Put a bunch of miles on it before you leave to give it a good shakedown to see what problems may crop up along with your preventive maintenance. Put together a little tool bag, extra couple plugs, etc unless your going to have 4 wheel support along the way.
Offline Whaleman
« Reply #3 on: March 20, 2015, 05:42:20 PM »
Need to know how many total miles on the bike. My first thoughts are bearing greasing, chain- sprocket, and points and condensers. Dan
« Reply #4 on: March 20, 2015, 05:56:12 PM »
If it runs fine around town, why might there be concern for riding 2 more hours?!
oil changes are always good as is tightening and lubing the chain.
Don't over think this. Get on it and ride.
« Reply #5 on: March 20, 2015, 06:35:53 PM »
exactly...ride it everyday...I like to shake down a new bike by traveling in ever widening circles.  If something is to go wrong, it will likely do so fairly early, so if you are only going around the block over and over, it's not too bad to push it home.  Once you are confident with that try a 10 mile block, then 20 miles etc.  Pretty soon you will find yourself in the next state!
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #6 on: March 20, 2015, 07:15:44 PM »
130 miles one-way? When I saw "roadtrip" I was thinking iron butt, not daytrip. I did 230 miles round trip last Saturday just to ride up to the Iron Horse Saloon in Ormond Beach to get lunch, and my only "preflight" checklist included tire pressure, oil level, lights test, and lubing the chain. Of course, I keep mine in a good state of tune, and I know my charging system is working like it should, and It's got a new battery. 130 miles won't even burn a full tank of fuel, and should get you near halfway home before you even have to stop for gas.
Like Stev-o says, go through the 3000 mile tune up (unless it's already been done recently), lift the front wheel, check for "notchy" or "grinding" of the wheel bearings. Do the same for the rear. Check the chain and sprockets for excessive wear if you are unsure of their mileage. The front sprocket wears faster and will show greater signs of wear as they rack up the miles than the rear sprocket will. I've ridden chain and sprockets until the teeth on the front sprocket were actually starting to bend over at the tips (of course I was young and dumb and broke).
Unless your cables are sticking (which might indicate frayed cables) all you should have to do is lube the cables. I've got 60,000 on my cables and had no reservations about the 3000 mile "roadtrip" I completed last June from Central Florida to Ohio and back.
Testing the charging system is easy, there's a good write up for diagnosing a 750 charging system (not familiar with the 550, but imagine they are similar) in my signature.
Make sure wheel/axle bolts are tight, handlebar clamps are tight (pucker factor increases when you try to stand up on the pegs while rolling down the road and the handlebars rotate under the force of pulling your self up on the pegs), make sure you don't have any spokes loose to the point of rattling, drive chain lubed and tensioned properly and not excessively worn, tires aren't more than six years old and properly inflated and not excessively worn, nothing else dangling or grossly out of place. You've left out a lot of details about the condition of the different systems on the bike so it's difficult to know what you've done or what you might have neglected. If you've covered everything I've listed here then you should have a bike that I would have no reservations about taking on a 260 mile "daytrip".
Last spring I did a 500 mile "daytrip" (round trip) up to Savannah, GA and back, again just to get lunch.
Jerry and Sean have good points as well.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #7 on: March 20, 2015, 07:20:52 PM »
Around here, we do that to get some ice cream up in the mountains somewhere!
...good ice cream...
Offline Gordon
  • 750K1, 550K2
« Reply #8 on: March 20, 2015, 08:08:01 PM »
Yep.
If it's running fine now, just keep at it and don't do anything drastic right before a long ride.  Check, adjust and change the basics as needed, and then go for a ride!
Besides, nothing builds character better than pushing a 35 year old bike 5 miles to the nearest gas station!  I should know.
« Reply #9 on: March 21, 2015, 02:52:54 AM »
Yep.
That ^^^^
Dont over think it, on a good day my commute from work is 100 miles.
While the office to home is about two miles.  My bikes has this problem of getting lost in Blue Ridge Mountains :)
Offline cbfivefitty
« Reply #10 on: March 21, 2015, 07:37:53 AM »
Thanks guys for the advice. haha well I use the word road trip more in terms of how the bike hasnt seen asphalt since 1994. Baby steps. I got the bike in December with 27000 miles barely running. I cleaned out the carbs, oil/filter change along with cleaning the gunk from the bottom of the oil pan, New tires and tubes, New battery, and cleaned inside of tank.
 Wish I could have done more but working out of a carport isn't fun in the winter.
Offline JimJamerino
  • Yay! I'm a
  • Not rich enough to be "eccentric."
    • My CB650C build thread
« Reply #11 on: March 23, 2015, 11:23:22 AM »
Mine too... except it's in the Black Hills of South Dakota. My 30-mile round-trip commute magically becomes 75 when I ride. Maybe my bike is actually a wormhole generator.
And to the OP: sounds like you've already done most of the required resurrection stuff. The 3000 mile tuneup does cover it all. Valves, charging, spark plugs, lights, fork oil... It sounds like a lot but it really isn't. Half of it is just a list of things to visually inspect and make sure it's not full of rodent dung, the other half is taking measurements or tightening or loosening a couple bolts.
~ Jim
formerly "emperorspartacus"
There are old bikers.  There are dumb bikers.  There are no old, dumb bikers.
My CB650C rebuild http://forums.sohc4.net/index.php?topic=74212.0
« Reply #12 on: March 23, 2015, 11:37:10 AM »
rofl....awesome!  ;D
