The SOHC/4 World Tour is in under way.
Oh no. Did you back off the adjuster screws on the rocker arms all the way before installing? Did you use rubber bands to hold the arms out of the way to avoid valve contact? It is very easy to bend valves when installing the cb500/550 valve covers. It sounds like you may have bent some valves on install and now the rockers aren't lining up to the stems.
Quote from: Trad on March 23, 2015, 03:47:11 PMOh no. Did you back off the adjuster screws on the rocker arms all the way before installing? Did you use rubber bands to hold the arms out of the way to avoid valve contact? It is very easy to bend valves when installing the cb500/550 valve covers. It sounds like you may have bent some valves on install and now the rockers aren't lining up to the stems. Sadly I think this is EXACTLY what happened. I tried to do everything as correctly as I could but I think I must have bent the valves enough to make the rocker arms not work anymore.
Quote from: valt on March 23, 2015, 05:22:05 PMQuote from: Trad on March 23, 2015, 03:47:11 PMOh no. Did you back off the adjuster screws on the rocker arms all the way before installing? Did you use rubber bands to hold the arms out of the way to avoid valve contact? It is very easy to bend valves when installing the cb500/550 valve covers. It sounds like you may have bent some valves on install and now the rockers aren't lining up to the stems. Sadly I think this is EXACTLY what happened. I tried to do everything as correctly as I could but I think I must have bent the valves enough to make the rocker arms not work anymore.Unfortunately it does sound like that may have happened. Sorry to hear it.
Quote from: FunJimmy on March 23, 2015, 07:03:15 PMQuote from: valt on March 23, 2015, 05:22:05 PMQuote from: Trad on March 23, 2015, 03:47:11 PMOh no. Did you back off the adjuster screws on the rocker arms all the way before installing? Did you use rubber bands to hold the arms out of the way to avoid valve contact? It is very easy to bend valves when installing the cb500/550 valve covers. It sounds like you may have bent some valves on install and now the rockers aren't lining up to the stems. Sadly I think this is EXACTLY what happened. I tried to do everything as correctly as I could but I think I must have bent the valves enough to make the rocker arms not work anymore.Unfortunately it does sound like that may have happened. Sorry to hear it.Well the good news is I can tell the one thing that won't happen when I get new valves / new head from ebay! Once again I prove to myself and the world that I don't have a clue what I am doing!
Why are you buying a new head if only the valves may be bent?First order of business is to remove the head, remove and label the valves (#1 intake, #1 exhaust and so on). Then test and measure them to determine if this is the actual problem. If so, you now have choices: replace only the bent valves, replace all valves, or replace the valves and have a bit of machine work done.If the latter is your choice, just make sure you take precautions with reassembly and you'll be fine. By the way, are you following the manual for torque sequences to install AND remove the head? It does matter for removal too...
Quote from: calj737 on March 24, 2015, 04:56:44 AMWhy are you buying a new head if only the valves may be bent?First order of business is to remove the head, remove and label the valves (#1 intake, #1 exhaust and so on). Then test and measure them to determine if this is the actual problem. If so, you now have choices: replace only the bent valves, replace all valves, or replace the valves and have a bit of machine work done.If the latter is your choice, just make sure you take precautions with reassembly and you'll be fine. By the way, are you following the manual for torque sequences to install AND remove the head? It does matter for removal too...He's probably buying a new head because it's cheaper than buying new valves from Honda or elsewhere after market. It's what I would do. After verifying the new, used head didn't have bent valves
