Author Topic: 77 CB 550F Headgasket  (Read 1071 times)
Offline hammy27
« on: March 18, 2015, 02:48:16 PM »
Just wondering if a headgasket can be done without changing the lower cylinder gasket.
Or will it be disturbed when changing the headgasket.
Thanks
Greg
Edmonton,Alberta.
Offline 78 k550
Re: 77 CB 550F Headgasket
« Reply #1 on: March 18, 2015, 07:41:03 PM »
once the head is off don't kick it over as it will lift the cylinder up. If you just replace the top and don't turn the crank you should be fine using it.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #2 on: March 19, 2015, 09:18:23 AM »
I've done it. Be carefull how you pry the head from the jugs and make sure ALL head bolts are removed. One time I noticed a bit of a weep from the base afterwards but it went away.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline hammy27
« Reply #3 on: March 19, 2015, 09:29:14 AM »
I will give it a try,Thanks.
Offline hammy27
« Reply #4 on: March 29, 2015, 08:30:57 PM »
Repaired head gasket leak all working good now.
