Author Topic: What are these lil' washers?  (Read 1193 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: March 26, 2015, 11:19:38 AM »
Found these while cleaning up the other day and I think they might go on the arms of the choke mechanism on CB750 carbs. They are 9mm OD, 2mm ID. Can someone confirm?
Offline harisuluv
Re: What are these lil' washers?
« Reply #1 on: March 26, 2015, 11:22:10 AM »
You have two different kinds there.  One is the washer for the choke linkage under the 4 cotter pins.
The one with the smaller ID is for the choke linkage but on the other side (airbox side) there will be a plastic grommet that goes in the hole, followed by that washer, then lock washer, then small 7mm nut.
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #2 on: March 26, 2015, 11:24:40 AM »
Thanks @harisuluv.
Offline harisuluv
« Reply #3 on: March 26, 2015, 11:47:12 AM »
Your welcome.
Offline iron_worker
« Reply #4 on: March 26, 2015, 12:00:44 PM »
The man knows his sh!t.  8)
*slow clap*
IW
« Reply #5 on: March 26, 2015, 02:00:54 PM »
