Author Topic: 1976 Honda CB750K First Build  (Read 26358 times)
Offline ponishenko3136
    • www.civilcustoms.com
Re: 1976 Honda CB750K First Build
« Reply #75 on: March 03, 2016, 06:57:59 PM »
now for some help. i have a mac 4-1 exhaust. can anyone help me how this goes on? the connector on the exhaust dont fit over the stock silver chrome things that go to the engine. i tried putting the mac exhaust without the stock tips on but they seem to long for the screws to fit properly. how would i mount this exhaust? thanks for any help
you don't use the original spigots.  Save them for if you change exhausts in the future.  Also, the original spigot screws are too short.  MAC supplies socket head cap screws with their pipes.  If you are missing them, you will have to source these...or better yet get studs and nuts, as already posted    ...and don't forget some new copper crush gaskets.
yes i have the bolts that came with the mac exhaust and new copper gaskets. so do i just put them in as much as they go and use the long screws? that will do?
Live To Build Another Day
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #76 on: March 04, 2016, 04:48:11 AM »
Yes!
If you want them in stainless socket head I can send you some.
Do you have a link to the fuel cap you're using?
--Evan
1975 CB750K "Rhonda"
« Reply #78 on: March 04, 2016, 01:47:20 PM »
put the exhaust on with some help from some previous posts. hope i did it right. they fit in right to the crush gaskets. i didn't put the muffler on yet just the exhaust
« Reply #79 on: March 04, 2016, 02:00:10 PM »
looks like you got it figured out...it may help to loosen the bolts you already got in a bit before installing the muffler.  Best practice is to get everything in place loose, then tighten everything up.
« Reply #80 on: March 04, 2016, 03:23:49 PM »
thanks, will probably have to do that
« Reply #81 on: March 04, 2016, 04:28:43 PM »
this is the one i got from carps
https://carpyscaferacers.com/shop/honda-cb500-cb550-cb750-parts-upgrades/alloy-flip-top-gas-cap/
That is a marine gas tank cap.  I think you can get them on-line for about $25.
« Reply #82 on: March 04, 2016, 04:54:11 PM »
haha that would have been nice to know a while ago when i bought it lol oh well, maybe next time
« Reply #83 on: March 04, 2016, 06:10:07 PM »
Sorry!
« Reply #84 on: March 04, 2016, 07:46:34 PM »
Sorry!
my fault for hurrying. live and learn
« Reply #85 on: March 13, 2016, 10:21:44 AM »
got a headlight from dimecitycycles and crg mirrors
« Reply #86 on: March 22, 2016, 09:40:28 PM »
ordered everything i need to finish this thing up, meanwhile i put on what i had. put on the throttle cables, clutch, speedo, tach, put the battery in and put on the led tail light and hooked it up to check it out. I'm pleased with how clean it looks. waiting on the m-unit to show up, wiring kit, and moto gadget turn signals. getting close to the final push
« Reply #87 on: March 23, 2016, 08:41:08 AM »
Thanks for all that. This is my first time doing anything like this, so it should be "fun" I have a bit of electrical know how and my friend majored in electrical so he'll help me out. once again thanks for the help. I hope I don't screw things up too much haha
« Reply #88 on: March 23, 2016, 08:55:03 AM »
FYI - Cal is the forum's resident guru on M-Unit wiring.  Something to remember.  Before you do trial and error, you might want to float your wiring plan to Cal and get his input.  If he gives you suggested changes, you should strongly consider them (or really just incorporate them).  He has wired and fixed the wiring on several bikes now.
« Reply #89 on: March 23, 2016, 09:39:25 AM »
awesome that's great to know. thanks. i might just do that if he doesn't mind lol
« Reply #90 on: March 23, 2016, 09:40:11 AM »
Let me know if you need help on the m-unit. I've done a few...
i sure will. i dont want to screw anything up and end up burning my bike down. thanks
« Reply #91 on: April 22, 2016, 10:24:30 AM »
while i was waiting for all my electrical components, i built a custom oil tank. i used parts from the original tank and made this one. I'm pretty happy with how it turned out.
« Reply #92 on: April 22, 2016, 10:25:51 AM »
and this is when it was just tacked up. everything is welded up and grinded and will be powder coated after tested for leaks
« Reply #93 on: April 22, 2016, 11:01:58 AM »
That's a pretty stout tank.
« Reply #94 on: April 22, 2016, 12:48:21 PM »
thank you
« Reply #95 on: April 22, 2016, 04:12:34 PM »
Installed the motogadget turn signals. Drilled little holes in the handle bars. Put grommets in to protect the wires. The installation was easy and I love how they look. And they are super bright.
« Reply #96 on: May 21, 2016, 05:06:27 PM »
finally got around to painting everything.
« Reply #97 on: May 21, 2016, 05:08:05 PM »
here's how it will look. still need finish the seat. powder coat the oil tank, drill the rotor, mount the caliper, and do the wiring. still some work to do but getting close to hitting the road and getting more and more excited
Offline jaycox
« Reply #98 on: May 21, 2016, 07:29:36 PM »
Nice, paint turned out great.
« Reply #99 on: May 21, 2016, 09:07:13 PM »
thank you very much
