For you guys who had your rotors thinned, what was the final thickness? I am mounting 750K wheels on my 78 750F and want to use the F brakes. The 550 rotors have the same diameter, but are 7mm thick compared to the 750F rotors which are 5mm.
Digger, thinned 550 rotors are probably your best option for fitting 6 bolt wheel hubs to the factory dual disc F3 fork. Before you have rotors ground, check the offset compared to either a 550 rotor or a 750K rotor. If the offset is different, it may possibly be corrected during the thinning process?
Mick, the Yami rotors I'm running are about 4 pounds lighter than stock 750 rotors. That's four pounds of flywheel mass, as well as four pounds of un-sprung weight. You can have your cake and eat it, too.
