SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Open Forums
Open Forum
Topic:
77 CB 550F Headgasket
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: 77 CB 550F Headgasket (Read 907 times)
hammy27
Full Member
on:
March 18, 2015, 02:48:16 PM »
Just wondering if a headgasket can be done without changing the lower cylinder gasket.
Or will it be disturbed when changing the headgasket.
Thanks
Greg
Edmonton,Alberta.
Logged
78 k550
Master
Re: 77 CB 550F Headgasket
Reply #1 on:
March 18, 2015, 07:41:03 PM »
once the head is off don't kick it over as it will lift the cylinder up. If you just replace the top and don't turn the crank you should be fine using it.
Paul
Logged
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Duanob
Bold Timer
Old Timer
Gotcha!
Reply #2 on:
March 19, 2015, 09:18:23 AM »
I've done it. Be carefull how you pry the head from the jugs and make sure ALL head bolts are removed. One time I noticed a bit of a weep from the base afterwards but it went away.
Logged
"Just because you flush a boatload of money down the toilet, doesn't make the toilet worth more", My Stepfather the Unknown Poet
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
__o
_- \_<,
hammy27
Full Member
Reply #3 on:
March 19, 2015, 09:29:14 AM »
I will give it a try,Thanks.
Logged
hammy27
Full Member
Reply #4 on:
March 29, 2015, 08:30:57 PM »
Repaired head gasket leak all working good now.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Open Forums
Open Forum
Topic:
